Platter Finish
Platter Finish
Platter Finish
Sean Troy
>Hey all, what do you recommend as a finish on a platter turned from some really nice quilted maple? I would really like the quilt to stand out. Thanks, Sean
Re: Platter Finish
Re: Platter Finish
Mike Schwing from Md.
>To each his own, but for me - Watco Natural, then when cured, lacquer.
Alternatively, light coat of sprayed (not brushed) golden oak dye, then lightly sanded to reveal the figure. Then lacquer.
But everyone will have their own favorite regimen. Each will have merit.
Re: Platter Finish
Re: Platter Finish
Wally Dickerman in Arizona
>Sean, speaking of really nice quilted maple for a platter, here's one. 22 inches in dia. Finished with 5 or 6 coats of Daly's Ben Matte tung oil finish.
Wally
Re: Platter Finish
Peter Charles Fagg (UK)
Re: Platter Finish
>Troy, for what it's worth. My platter in English Sycamore (Maple) is finished with pure beeswax, nothing more nothing less.
It is not such a great quilting as can be found over the pond but nevertheless still carries some beautiful grain.
Peter
Re: Platter Finish
Apologies, Sean!
Re: Platter Finish
Mylands Cellulose Sanding Sealer
>This one - sanded to 12000 Micro Mesh, 3 coats of Mylands Cellulose Sanding Sealer wiped on, buffed on 3 wheels.
Same with this one:
But this one was oiled (Watco) and lacquered (Fuhr)
Just 20 or so coats of lacquer on this one (Fuhr pre cat water based)
Re: Platter Finish
Re: Mylands Cellulose Sanding Sealer
Sean Troy
>Mike, why do you use sanding sealer? sean
Re: Platter Finish
because it looks good?
>Frankly, because its quick, easier to work/rework than lacquer, buffs up wonderfully, and looks great. It is not as hard or durable as lacquer, and a bit softer, so it works more easily. Sometimes I use lacquer over it, but normally I'm thrilled with the appearance without it. It is no replacement for lacquer, if you're after a real lacquer finish/shine/gloss, but it looks pretty good, eh? My customers like it, too.
Re: Platter Finish
Re: Platter Finish-- WOW
Dave Fuqua
Re: Platter Finish
Re: because it looks good?
Dave Fuqua
>Out of curiousity, how durable is it? Will it stand up to a lot of handling. It looks fantastic, as does the waxed platter Peter posted. I'm just curious if you have done anything with the same finish that a lot of people have handled. Does it hold up well?
Thanks,
Dave
Re: Platter Finish
>It holds up well enough for me. I have only several years worth of experimentation to lend you on this, but I'm staring at a few things right now that have been finished thusly over the last 3 years. They all look pretty good to me. This is not a replacement for a fine, time consuming lacquer finish. Nor will it be as durable as multiple coats of a film finish, but it'll shine up and last better than wax.
Don't take my word - try it yourself on a piece and fondle it over and over again for a couple of years. Report back!
