A couple finishes
Dominic Greco in Richboro, PA
>Bert,
Osage is one of my favorite woods to turn. Don't be put off by everyone saying "The bright yellow color won't last....". (funny how you don't hear something similar about cherry's color darkening) Yes, it does mellow over time to a rich golden brown. But I think it's just a pretty.
As for finishes for Osage, I prefer to wet sand to 600 grit with a 50/50 mix of Varnish/Mineral Spirits. I use McClusky's Spar varnish (in the red can). I was told that you should use a varnish that has Alkyd resins in it to help stiffen the fibers of the end grain.
This wet sanding fills the open pores of the wood and gives you an ultra smooth surface. I then let the bowl dry for a week and apply Watco's Danish Oil.
I've also used Woodcraft's Urethane Oil, and Tried And True's Original Wood Finish with success. Both work well, but I prefer to use wet sand (as I detail above) first.
Good luck,
Dominic
