orhard wood ,good or firewood???
Kevin Turner
>I've posted this on the other forum I enjoy. An Orhard is being dozed at the end of this season. This orhard was started years before I was born. ( over 40 years ago).. Folks are concerned about the pesticides etc in the wood. Now Is this wood useable? Or fire wood?.... keeping in mind that we all ,at one point , ate an apple... Any thoughts...????
Re: orhard wood ,good or firewood???
Bob Hackett
>Get as much as you can haul and forget about the pesticides!With the price of heating oil going up I`m surprised the firewood guys aren`t there already.
You may want to ask about drying methods as apple is a bear to keep in one piece.Look at it this way,if it does crack you can use the peices for saw handles or planes.Too small for tools,use it in the smoker.It`s almost as good as mesquite.
Mainely,Bob
Mike Schwing from Md.
>You are not going to find a definitive answer to your question. This comes up several times per year around here.
Personally, I wouldn't be concerned about pesticides unless you happen to be a pest. I've turned and burned a lot of apple wood. I'm still here. I don't worry about it, something's gonna kill me, and I figure that with the 40 years of other accumulations in my body, whats a little more going to hurt?
what about lumber???
Kevin Turner
>Will this saw up well?
Kevin Turner
>How about the root bulb???? How would it turn?? I've been called many namews but thats' the most Tame to date...And to this day I always wondered if the "Teacher ate that nice shiney apple".LOL..
Apple roots and burls are gorgeous
>Turn like cream, with a few rocks and dirt thrown in.
Re: orhard wood ,good or firewood??? *LINK*
Russ Fairfield
>There is an article on what I do with apple tree wood in the archives. I treat all fruit and nut tree wood the same way.
You will get different answers on the question of pesticides. I would have less concern about an orchard tree than I would about a backyard tree. Because of the expense, pesticides are used more sparingly in the orchard.
As to toxicity of the wood, my opinion is that the half-life of any chemical is such that it has been rendered non-toxic before now. That may not have been true in the days when lead based pesticides were used, but that was longer ago than 40 years. You have probably ingested more pesticides from dusting the roses than you will get from turning a piece of wood from a tree that has been sprayed. And, remember that is only an opinion.
Bottom line?? If the pesticides are a concern, forget about it for either turning or firewood. The same residual pesticides are there, whether it is turned or burned. Some say that they are destroyed from the heat of burning, while others insist that the heat from an open fire will only release the chemicals in a higher concentration. Which you believe is your choice.
Turning Apple Wood
Yep.
Bob Hackett
>Around here apple was used as a substitute for cherry.Harder to dry but just as nice.
I see at least another 5 gallon bucket of Anchorseal in your future!
MB
