Pulled the plug
Pulled the plug
Pulled the plug
Don Henthorn
>and ordered a Husky 345 today. It is a toss up how well I will do at wood gathering, but figured I might as well try. I have some magnolia trees in front of the house that have developed some really low hanging branches. So today I duct taped a pruning saw to the end of a 13 foot piece of conduit and cut the long branches down. Boy! did that tucker out this old man, but I got it done. Tomorrow I will pull them around to the back alley. With the new saw I will be able to quickly cut the branches up to the required size for removal by the city. Will have a few pieces that will work for spindle turning.
Re: Pulled the plug
Re: Pulled the plug
GeeSeaWhy
>Don,
Be careful cutting up branches with a chainsaw. I'm no expert but I read somewhere, possibly this forum, that if you don't have enough of the saw's teeth engaged in the wood it will kick back. That's something you really don't want to experience.
Graeme
Re: Pulled the plug
Re: Pulled the plug
>My favorite pruner is a reciprocating blade that fits on an extension for my weedeater (Troybilt). I haven't measured, but I think I can reach over 15'. There are also chainsaw pruners on long poles but you have to do a lot of pruning to justify the cost.
What scares me about pruning most limbs with a standard chainsaw is that I usually have to climb a ladder or the tree to reach them. I hate working the saw without my feet firmly on the ground. A very light saw helps but it still scares me.
And yes, Graeme, small branches can be grabbed and jerk the saw. (Vines are the worst for this.) This can be minimized by placing the branch back against the rest at the bottom of the blade before pulling the trigger. Unfortunately, this will not let you prune properly but will cut the branch too far from the tree. However, branches small enough to cause a problem with the chain saw can easily be cut with hand saw or bypass lopper.
JKJ in East TN
Re: Pulled the plug
Re: Pulled the plug
Jorge Castaneda
>Don
Gee is right,
small branches have a way of causing kick backs, my prefered method if they are still attached to the tree is to place the saw under the brach and then bring it up, if it was cut already from the tree, place it on top of a stump and let the amount you want to cut hanging out and hold them down with your foot, then as before place the saw under the branches and slowly bring it up, that way it cannot jump for the jugular.
That is a good saw, you'll be glad you got it.
Jorge
Re: Pulled the plug
Re: Pulled the plug
Don Henthorn
>Yep. I have cut my share of branches and many people watching me thought I was being careless because I worked pretty fast. However I understood the mechanics of what was happening and always felt in full control of every cut I made or I wouldn;t make it. I am also fuuly aware of the fact that my faculties are not what they they were just a couple of years ago, so I will be much more careful. Never-the-less, I appreciate your warnings and will keep them in mind.
Re: Pulled the plug
Re: Pulled the plug
Carole in VA
>Well Don, I know you are a decent ways inland from the coast, but it looks like you may need that new chainsaw to clear downed limbs and such from this latest monster unless she dies immediately upon striking land. Be safe.
