We value your privacy.
>I may have a chance to get a deal at Auction on one of 2 Ringmaster Bowl Lathe tools soon. I don't know much about this tool, other than what I have seen on the internet. They look like a neat tool, and could possibly be enjoyable to use. Is there anything to look for, or look out for when looking at this tool? I have found some information on the Net about them, but I figured I would go to the collective wisdom of the members for advice, or comments. Thanks in advance for any comments, or information!
They are a neat looking tool. I have no idea what to look for that would make one ringmaster a better tool than the other.
Unfortunately the resultant product is less than you might hope for. At least the end products I have seen. The walls of the bowl are straight sided and there is a lot of tear-out in the bowls. I suppose that the type of wood used makes a good deal of difference in the end product. I also suppose that a sharp blade would yield better results. Still, when the guy at the woodworking show was doing a demo several years back I couldn't help but notice that the side of the rings showed a lot of tear-out and all the bowls on display had these straight sides.
>My dad has been using a ringmaster incorporated into his Shopsmith for about 15 years now. Not a bad little jig. Need to watch your tool bits for sharpness and relief on the sides. Yup, it does have limitations to the end product. Angle of the bowl is dependant on the thickness of the stock. Mixing and matching wood grains, rotating the rings during glue up, and a few little enhancements can make some pleasing bowls within it's capabilitys. Dad normally cuts rings for several bowls one day, glues them up in a special clamping jig we made the next, spin sands them the next day, then finishes them on the 4th. All in all, about an hour labor per bowl when built that way. Supposingly was orginally designed by a highschool shop teacher who was seeing kids bring in large expensive planks, chop them to pieces to glue them up, then machine away 90% of that valuable plank to create a bowl. From a single 3/4" thick plank 8" square, you can yield about a 7.5" diameter bowl of varying depths with this jig. Do make nice bowls, but within limitations. Does allow you to purchase wide planks with several knots at a reduced rate, and still yield some good product from the lesser expensive lumber. Good luck bidding.....
>You can do essentially the same thing with a bandsaw by cutting half a ring out of 2 parts and then gluing them back together to form a single ring. Vary the angle of the cut to change the shape of the bowl or vessel. This has been done for years. I saw an article on this technique many many years ago in fine woodworking and made several of the pieces. I had forgotten about the technique until I bough Malcolm Tibbets book on segmented turning.
I also used the same technique as the ringmaster to build the tornado we entered in the AAW challenge many years ago. I put a piece of 3/4" wood on the lathe and then parted off rings using a thin parting tool. I could get 2 rings out of each large ring. Maybe 20 out of the 12" piece. Then just stack the rings and glue them together to form your shape.
