Screw Center
Screw Center
Screw Center
W.C. Turner
>Hi,
I recently tried the screwcenter, that came with my Vicmarc VM120 chuck, for the first time. Judging from the gall marks, on the screw base, where it fits in the chuck jaws, it did some spinning around while turning.
Anyone else tried the screw center in your chuck?
What are you supposed to do, really crank down, on the hex key when tightening?
How do you keep the screw from spinning while in use?
Thanks,
W.C
Re: Screw Center
Re: Screw Center
Mark Kauder, Phenix City, AL
>WC,
Best way to keep it from spinning is to get the Nova or Oneway screw center, they have machined flats on them corresponding to the jaws. That a major complaint about the Vicmark Screw center.
You could grind the flats on your screw, if you can do it evenly.
Mark
Re: Screw Center
Re: Screw Center
>Barry Except for a production run of a dozen platters I have never used my screw center. I just can't make myself live with the restriction of mounting a bowl and then not being able to change it like I can when it's between centers. That being said I haven't had my screw center for the vicmarc slip but then I do really crank down on that.
Re: Screw Center
Brian McKearney
Re: Screw Center
Brian McKearney
>I recently tried my screw center for my Vicmarc 120 and was rather impressed. Based upon my past experience with an older "original Nova chuck" (with tommy bars), I didn't care for screw chucks. But after giving it a try with the Vicmarc, I found that it was pretty nice to use and held very firmly. I did crank the work piece on pretty firmly (hand tight) - after parting off my finished piece, I did have to use a pipe wrench to loosen the scrap wood. Perhaps I screwed it down too tightly? I also tighten the hex screw pretty firmly (hand tight with two hands).
For what it's worth, hope this helps...
Brian
Re: Screw Center
Brad Vietje
Re: Screw Center
Brad Vietje
>W.C.,
Is the screw center designed to be used with a particular jaw set ? The Nova/Supernova "Woodworm Screw" is made to compliment the 50mm jaws, and fits a few others, but isn't meant to be used with most of the accessory jaws... Might this be the same with the Vicmarc line ?
Safe Spinning,
Brad Vietje
Thetford, VT
Re: Screw Center
Re: Screw Center
>Brad I've used mine on 3 of the 4 sets of jaws I have. They all work fine on the Vicmarc 100.
Re: Screw Center
Re: Screw Center
vicmarc.fan
>I hope semeday the guys in NZ and Australia understand Americans need something in the way of instructions with the tools we buy from them. The tools I have from Canada all came with ample instructions and an 800 number if we had a problem understanding the instructions. My new lathe came with a booklet that was so outdated it didn't list the new parts in the exploded drawings. If you have ever got anything from McMaughton, Kelton or Vicmarc for example you have to figure it out on your own. I say this rant because why do we have to ask each other how to install a part on a chuck that comes with the chuck? Don't get me wrong, I have three Strongholds and two Vicmarc chucks and I find the Vicmarc chucks to be the best for a number of reasons. Still I don't know for sure how to answer this question. I know what I do. I use the regular jaws and put the screw in so just a little of the shaft where it is larger than the part that has the threads and as you close the jaws the screw will no longer fall through the chuck. Where the screw is the largest fits behind the jaws and the 4 jaws clamp the screw on the larger part of the screw shaft. You do have to use some force to lock the screw in place. When the screw is in right there will be no wobble at all. Don't know if this helps, I hope so.
Ron
Re: Screw Center
Re: Screw Center
Barry Turner
>I have a SuperNova chuck. The woodworm screw that came with my chuck has flats that engage with the jaw slides. This prevents it from turning. Are you sure your screw doesn't have flats on it, too?
Barry
Re: Screw Center
Re: Screw Center
W.C. Turner
>Mark: I hate to have to buy a new part, to replace, the new part that came with a tool.
Brad: As far as I know the screw works with any of the jaws. As the other poster said, Sadly lacking instrustions.
Ron: I installed the screw in the jaws, just as you described, but the gall marks on the smooth shaft, showed that some twist had occurred.
Barry: No flats or lugs on this one. Take a look at the VM120 in the Packard Woodworks catalog, it shows a good photo, pg.15 in my spring catalog.
The screw holds the stock firmly, I just don't like the twist, only the Chubby Checker version.
Re: Screw Center
Re: Screw Center *LINK*
I have six Supernova or Supernova2 chucks and each came with a screw or two and I don't use any of them. You want maybe I should send you one in the mail? Trade for something?
I do use a screw chuck (usually on bowls cut from dry planks) but I far prefer the Glaser screw chuck. It has a reversable/removable coller that provides three different bearing surfaces against the wood for different sized pieces. Unlike a chuck with jaws, it is smooth around the circumference and much smaller, so it provides more clearance at the headstock end. However, if you don't want to spring for a screw that works better, I doubt you'll want to buy the Glaser - it's a bit pricy. :)
JKJ in East TN
Glaser Screw Chuck
Re: Screw Center
Re: Screw Center
ken chase
>It is real fussy to properly seat. I tried one made by
Oneway that seats a bit better.
Ken
Re: Screw Center
Re: Screw Center
>I use mine w/o any jaws in place. Mine tightens on the slides, which give me a large 4" (relatively) flat surface to register against - just like the high-end dedicated Screw Chucks.
Mark
Re: Screw Center
Re: Screw Center
Barry
>Packard has some screw chucks that are not quite as pricey as the Glaser and work pretty well. I think I gave about $34.95 for mine. I like it better than the woodworm screws that go into 4-jaw chucks. I have one that I use on my Jet mini lathe. I'd love to have a Glaser. Maybe someday.
Re: Screw Center
W.C. Turner
>I usually start between centers. I had seen Raffan use a screw on his video, & decided to try mine. Not sure how much I would use one if it worked well, & no spinning.
How do you know yours will work with a Vicmarc?
Thanks,
W.C.
Re: Screw Center
L.H. Glaser screw chuck...
Wally Dickerman in Arizona
>Jerry Glaser made two screw chucks for me with left hand threads, and for a left hand threaded spindle. (My lathe is a Nichol's left handed bowl lathe) Nearly all of my turning is done with a glue block and a screw chuck. Works for me...
Wally
Re: Screw Center
Re: JKJ
I have no Vicmarc so I can't be sure. If you want to try it send me an email and I send you one.
JKJ in East TN
Re: Screw Center
vicmarc.fan
>You may not be following this anymore but if you are I thought about your post when the Stronghold and Vicmarc chucks were laying together on my bench. Someone said the stronghold screw will fit and it does. The problem is the bodies are different. The stronghold jaw holders are triangler in shape and fit into the 4 notches of the screw. The vicmarc body is round and the jaw holders do not move inward so there is nothing for the notches to catch on. I admit I really crank down on the screw in my Vicmarc chuck. The only time I use the screw is when I want to core out a blank of green wood. I don't find big chunks like I used to but I have had no problem. If you want to replace the screw this guy is good.
1-866-630-1122
Ron
http://www.turnrobust.com
