Small Segmented Bowl
Rob Ceraso
>Hi All-
This is a small bowl inspired by some of the simpler pieces in the Ray Allen book on segmented turning. It is about 5" x 5" and made from chechen, maple, cherry, and African blackwood.
I appreciate any criticism - positive, negative or anywhere in between. Very few people commented on the last pic I posted a while ago of a set of segmented salad bowls and none of the "regulars" that I'd hoped to hear from (no offense to those who did comment).
I'll be the first - I used titebond 3 which is considerably darker than the other titebonds and it shows the glue joints in the light woods a lot more than I would have liked. Other than that, I am pretty happy with it.
Thanks,
Rob
Re: Small Segmented Bowl
Mark Kauder, Phenix City, AL
>Rob,
Well done. Not much to critique here. Shape is good, curves are great, curve transitions are good, joint alignment is good, color/wood selection is good.....what's not to like.
Regular lighter colored Titebond does not show up as much in the light wood joint, and has no negative effect on the dark wood joints. Also, I hope you are clamping your rings during glue up. Clamping help minimize the visibility of glue joints in lighter wood - less so in dark wood. I use Titebond I, it comes off your clothing and clamps, etc much easier, and the more water resistant versions are not necessary. No one will be putting water in these.
If you want to add "Sparkle" to the next one (?):
1) Make the wall thickness (at least at the neck) a little thinner - it will give it a lighter look, even if the rest of the bowl is that thick.
2) This one could have used the alternating veneer band under the neck, just like under and over your design ring. Hsving the veneer bands over the base piece would not have had much effect either way on this one.
3) Make the base about 1/3d the the largest diameter on artistic (vs functional) pieces (bowls, vases, etc).
4) On small pieces, make the layers thinner. My general rule for ring height is: If you have a wood where the wood grain is the spactacular feature (Zebrawood, Birdseye Maple, etc) allow the segments to be large (fewer per ring, and thicker) to show it off, if the grain is not the distinguishing feature (Yellowheart, Purpleheart, etc) make the segments thinner and have more segments per ring. This increases the "Sequin effect", where the segments all shine differently under the light. Regardless of wood, smaller bowls get thinner rings, just to look better to me.
Now, all that said, I will repeat: This is a really nice little piece. Well done. Keep it up.
Mark
Rob Ceraso
>Hi Mark -
Thank you for the comments and advice. Coming from you, it means a lot.
Thanks again,
Rob
Kevin Turner
>Nice bowl. I've been searching for that books. I guess I'll need to order it .... Whats' the bottom look like?? I've been using titebond III for over a year. More fillers in the glue. But I like the open time...Cheers
Brad Vietje
Pretty Little Bowl, Rob !
Brad Vietje
>Say Rob,
That's a nice little bowl. I read Mark's comments, and learned a lot just by reading. I did notice right away that it would really stand out with a thinner wall at the neck. Please show us your next one, too !
Safe Spinning,
Brad Vietje
Thetford, VT
Keith Tompkins
Keith Tompkins
>Hi Rob, I must agree with Mark here....a band of veneers at the neck joint will have a nice effect, and tie the overall appearance together. Also something contrasting on the rim, instead of just seeing the plain glued segments. You have avoided a major problem many segmented turners have....your form is flowing and continuous, and does not flatten out at the detail ring. Nice work!
Very Nice
Dick Parr
Re: Pretty Little Bowl, Rob !
Rob Ceraso
>Thanks Brad. I learned a lot from Mark's comments as well and I'm grateful that he took the time to write them.
