Making Chucks
Making Chucks
Making Chucks
John Patrick
>Hi,
anyone know a good site for making ornament turning chucks? I wanted to try my hand at making the chuck before I went out and bought one.
Thanks,
JP
Re: Making Chucks
Re: Making Chucks
>John You don't need a chuck to make an ornament depending on what type of ornament you make. I make a 3 part ornament, ball, long finial and short top finial. You can make the ball part by gluing the wood to a wasteblock on a faceplate or if you have plenty of wood screw the wood to the faceplate. Turn and hollow the ball and then par it off.
You can make the finials by turning a #2morse taper on a 1" piece of timber. Jam it in the headstock, move up the taistock and turne the finial. You can do the same thing for the small finial although I usually try and leave enough wood from the long finial to turn the short one on what's left in the spindle.
You can also turn the two part hollow ornament on a waste block. Rough turn the stock and turn a tenon on both ends. Part the wood in two. Turn a hole to match the tenon, in the faceplate. Glue the bottom of the ornament in the hole. Hollow this portion. Rough turn the outside and part it off at the faceplate. Turn another hole in the faceplate to match the tenon on the top part of the ornament. How hollow this part and rough turn the outside. Bring up the tailstock and glue the two halves together. Now you can finish turning the ornament.
Re: Making Chucks
Re: Making Chucks
Moshe Eshel
>Hi,
I have yet to start trying ornamental turning but I have been reading and looking for info about it...
I couldn't find chucks for sale or any ornamental equipment, it seems that most of those who practice this art build themeselves. If you find a source to buy, please share it with me...
If you want to build yourself, I suggest buying these books (the link is to amazon, feel free to buy them where you get them cheapest):
1. The Principles and Practice of Ornamental or Complex Turning
2. Ornamental Turning
3. Turning and Mechanical Manipulation
4. Hand or Simple Turning
I hope the links work, read about the books, these are about how to build almost anything connected to turning...
Have fun!
