More wood booze stuff
Ed Karch in No.VA
>A nice lady called me up and said they had sold their property to developers and would I like some wood. I sawed and hauled 6 truck loads of large cherry, pecan, paulownia,and black walnut. She requested a slab of black walnut for a centerpiece base. This wood was so wet that standing a piece on end would result in a puddle of water draining out of the wood.I cut about a two inch thick slab and soaked in DNA for a week. I pulled it out and bagged it for a week then it started to crack not from the center but half way out toward the edge. I re-dunked it for a couple of days and the cracks closed. It is now bagged again and I will check in a couple of days to see if the cracks open again. I noticed this on bowls, that DNA after cracks would sometimes close the cracks. Has any one else seen this?
Another thought. if spring/summer cut wood has loose bark due to active cambium. would a DNA soak remove enough water to stablize the bark? The walnut slab has intact bark so I will moniter for this also.
Oh yes I gave her bowls of pecan, Paulownia, maple, and one drying in black walnut, so she can have something to remember her trees by.
Ed
Re: More wood booze stuff
Barry Turner
>Re-hydrating your blanks may close the cracks, but it's not going to heal them. They're still there......just not visible. Sorry.
If I were you, I'd saw those blanks in half lengthwise and coat the end grain with liberal amounts of Anchor Seal.
Barry
Ed Karch in No.VA
>Yep they are still there but as this is a 2" thick cross section of a log they wont be exposed by turning as this won't be turned. End seal will work but would also goop up the slab so it couldn't be used as a centerpiece base. I can always just slice another tranche and give it to her green and let her watch it crack. This thing will end up being much more trouble than it is worth.
