On the drying rack this morning.
Dave Smith, Longview, WA
>I turned the plates last night. I had the vessel outside turned last year and was not looking forward to hollowing the dry spalted bigleaf maple. I figured out how to use the ring tool Charles Martin gave me and once I found the sweet spot the vessel didn't have a chance. I used the ring tool on the plates and had better control turning the corners. What a deal, auction off a plate and get a tool that allows making more plates easier.
Clockwise from lower right.
Big leaf maple about 7.5" square.
Koa about 6" square.
Elm about 6" square. Dyed with cardinal red.
Big leaf maple vessel. Hollowed out with my new ring tool.
All will get a second coat of Rockler’s Gel Polyurethane this evening.
I was going to dye the koa but I knew sandy would pitch a fit if I did.
Do you see anything worth auctioning?
Dave Smith
Turning and burning in Longview, WA.
Re: On the drying rack this morning.
Jennifer@Indy.USA
>Dave...a great assortment! Next time you're in town...I'm up for a lesson in ring tools. I bought one a few years ago....and it's still scares the heck out of me! I think I've gotten it to cut for a total of about 7 seconds in umpteen tries.For me, it's a real white knuckle tool!
Your plates are, as always....wicked!
Jen
>The Ring tool definitely has a learning curve. I have 3 and they all cut a little differently but once you get a feel for them they really remove wood.
>Dave Those are really nice especially the one in the lower left. John
They scare me too...
David Propst
>Hey Dave,
I like 'em all, but the bottom left one takes the prize. As for ring tools I agree with Jen. I bought a Termite tool about four years ago and have never been able to quite figure out what I was doing wrong with it. It is resting in the bottom of my tool cabinet. Maybe I need another lesson from you!
David
Molly Winton
>Yeah, that Koa one does it for me too. It's an eye-popper. Great work Dave.
Thanks for your kind comments.
>The plates are not too difficult it just takes time the first couple you do.
That Koa came from Hawaii Turner aka Doug Leite. I trimmed and resawed a piece that was about 1 7/8" thick. I knew the figure would be awesome. I have an other one to turn. Maybe tonight. The elm and big leaf maple were pieces trimmed form bowl blanks.
The ring tool has a 1" diameter cutter. I am not sure I am using it as designed but it is doing a great job for me. I need to get a better rotary sharpening stone to get a more consistent cutting edge. The tool did startle me a couple times but I have done worse. I just treat it like a bowl gouge and present the cutting edge similarly. I don't use learning curves. I just fake it and the tool and wood don't know any better.
Mr. Propst knows how well I fake bowl turning.
Dave Smith
A little square when it comes to turning in Longview, WA.
Re: They scare me too...
>I'll try to shoot a photo tomorrow of a ring tool in use. I have to rough out some bowls and I can use the ring tool to do that so I'll shoot something for you.
Re: Thanks for your kind comments.
adrien
>Dave, I join the group in admiring the Koa piece.
But would you kindly elaborate how a ring tool helped you to
turn the square corners on a flat piece?
Ed Karch in No.VA
>Great stuff Dave. Any of the lot would make an auction piece.
I have ripped the tenon off more than one piece learning to use a ring tool.It is all in the angle of attack. One small moment of inattention and you can chase that pot across the shop.
Ed
Chasing pots in Northern Virginia.
Termite
Garrett in Victoria
>Hi David
I discovered the hard way that at least two keys to success with the aggressive Termite is to keep the RPM's very low and the bevel rubbing.
Cheers, Garrett
tutorial
Pascal Oudet
>This article might help (I hope so)
Pascal
