We value your privacy.
>I know the photo experts can find fault with this one because there is a lot wrong with it. However, the color is as true as I could get it. It is bright enough to show one level of a beautiful hidden grain pattern. You will have to shake your monitor to see the grain move from the chatoyance, and believe me, there is an abundance of it. This looks like it is on fire in real life. It looks the same on my screen after posting as it was before. And it is slightly out of focus.
The bowl is 18" diameter. The wood is from a Western Red Cedar root burl. I have never found this kind of wood above ground.
>Can't comment on the pic, I'm still trying to work my technique out as well. As to the bowl, absolutely beautiful. Just wish you would post a few more.
>Looks fine to me. Looks like you were able to pop the color and grain. I almost think you started with a lacquer seal and went from there. I have seen several bowls photos here which were sealed with Watco, too me that darkens the wood and you can't see the grain and character. GT
>Russ It looks great on my Monitor. I have an older monitor and is really hard to pick up and move so I could see the Chatoyance. Got to get one of those flat screen jobs. By the way My Boss and I have been working on a way to spin work on the web page so you could actually see the Chatoyance. We've worked out everything but but the background. On larger pieces you can see the circular cutout whick really looks bad..It's been put on the back burner for a few months because this time of year we don't have time to do anything.
>Now that's what I have been trying to capture...at least enough to indicate that if you were to handle the piece in person, you would see the chatoyance. You did a much better job of doing that than I have been able to. What sort of lighting did you use? That's a gorgoeus piece of wood, BTW!
Actually, that's possible! Back in the '80s a neighbor/associate of mine at ORNL devised a method to view 3D images on a computer monitor by "shaking". He created multiple views of the object, each with just a small angular rotation, than rapidly switched between the views. This tricked the brain into seeing in 3D, and although the image shake was apparent and probably not useful for general 3D viewing, the effect was stunning. (especially 20 years ago!) He developed his method to view complex chemical molecules.
This might be adaptable to viewing chatoyance if the wood object was stationary and you moved the point light source just a little between successive photos and created an AVI/MOV file. I never discussed the details with the gentleman, but I suspect the speed of the images would be critical and related to the physiology of the eye/brain (think film and video frame rates) and the varying decay characteristics of the phosphors and LCD elements of various display monitors.
Thinking further, a simple video with a slowly moving light source might show the chatoyance effect nicely in 2D. Anyone try that?
>The lighting is really high tech, three 300w incandescent bulbs with reflectors and white umbrellas. The bulbs are frosted because that is what Ace Hardware sells. 1 of the lights is reflected from the umbrella, and the other 2 are diffused through the umbrella. The background is black photo paper.
I think the real secret to making a photo like this is working in a totally dark room, and having 100% control of the lighting. My camera is a Sony 717, and it wants to see daylight. Even a small amount of daylight will dominate the picture.
Something that I have found very helpful for taking this type of photo is hooking up a monitor to the Video port on the camera. With some adjustment of the monitor, this will allow me to see what the camera is seeing. That helps get the lighting, focus, and color right. Then taking several images by bracketing around a lens setting and shutter speed will get me a good picture. The bracketing is easier when it is automatic.
>If the chatoyance can be seen with our eyes when we move the light, we should be able to see it in a video. I tried it and came to the conclusion that it would take a lot better video camera than what I have before I could do that.
>Hold on here Russ- this looks like direct on camera flash from the highlights and hard shadows! A fellow strolled into my booth at a show recently and discussed digital 3D photography he was promoting. He mounted 2 digicams side by side and viewed the images with red/blue glasses similar to the old stereo slides my father played with for years. You then had to visit his web site and view monitor with the glasses- was very interesting, with some subjects better than others. And now I have no idea where the site URL is- I probably tossed it into the circular file.
>Mmmm...Russ that is beautiful. What a terrific form. The wood is incredible and the finish looks perfect. Beauty! The photo looks great too. Like the bowl is floating in air.
Did you find the redwood burl to tear out at all? I bought a piece of it once and was rather surprised at how soft it was even being a burl. I never did get quite the cuts I would have liked.
>The finish starts with the wet wood turned to final dimensions and rough sanded to 150-grit while it is still wet. Then it is submurged and allowed to soak in my "Special Finish" for 3-weeks; allowed to dry for another 3 weeks; returned to the lathe and sanded through 600-grit with the finish used as a lubricant; lowed another week to dry; and finally buffed on a Bealle wheel with the White Diamond.
I do this with all large pieces of Cedar and Redwood because it cures ring shake and prevents splitting.
This "Special Finish" is 1-gallon Boiled Linseed Oil, 2-gallons of odorless Mineral Spirits, and 1-quart McCloskey's Gloss Spar Varnish. There is nothing special about the Odorless Spirits, I use it because it smells better than the regular kind.
This mixture is as good as (I think it is better than) the latest version of the Watco Danish Oil by Rustoleum for 1/3 the cost, and it can be used the same way as the Watco Oil for regular finishing.
>Tear-out is always a problem with Western Cedar and Redwood burls, regardless of how sharp the tools or how good our turning skills. Fortunately they sand easilly. I start at 60-grit and power sanding.
>About mineral spirits- I was recently replacing some golf club grips, and the kit had a solvent that said mineral spirits but had a citrus-like aroma. Have you ever encountered such?
>Yes, I have. Citrus is being pushed in the market place as a replacement for the petroleum products. Some of them are genuine, but a lot of them are orange flavored paint thinner (Mineral Spirits).
The real thing is d-Limonene, the oil that is extracted from the peel after squeezing the oranges for their juice. d-Limonene can be used as an alternative to xylene, mineral spirits, and a list of other hydrocarbon solvents. It is soluble in water and will dissolve paraffin, glues, many finishes, and most adhesives. I suspect that this is what you were using.
The Citrus flavored finishing waxes are a carnauba wax where the hydrocarbon solvent, usually Toluene and Mineral Spirits, has been replaced with a d-Limonene solvent. It evaporates more slowly than the hydrocarbon solvent, but leaves a pleasant citrus aroma with the wax.
The jury is still out on whether d-Limonene is a carcinogenic substance, and to what degree. Meanwhile, read and obey the warning labels.
Yes, I forgot to mention that after bathing it in incandescent lighting, I popped the grain and corrected the color with the flash and a white handkerchief over it.
