We value your privacy.
>Is it just me, or is there really a darkening and loss of contrast of some photos that occurrs as it is transferred to one of these Websites for posting?? It happens both here at WoodCentral and on WOW, but it is worse here. It doesn't happen when I post photos to the server for my own website, it doesn't happen when I send the same photos via E-mail, and it doesn't happen to all photos.
The number of dark photos would tell me that others are also having this problem.
I have solved the problem by increasing the brightness and contrast on photos that are going to be posted on WC and WOW. Since both are different, and it doesn't happen with every photo, I have to make several tries at editing to get a good photo on-line. Is there a better way??
Re: Another photo posting question for the experts
>>...is there really a darkening and loss of contrast of some
I don't consider myself an expert on anything and I don't have any knowledge of what goes on under the hood here, but I did one test that you can duplicate (or send the files to me and I'll check them). I located an image that I posted earlier and grabbed it from the browser. I also loaded the original file I had sent to WoodCentral. A visual comparison showed no difference. I saved both files as TIF, then did both binary and subtractive image comparisons. Not surprisingly, the binary comparson showed the files to be unequal. However the images subtractive comparison showed no differences.
In addition, I have personally not noticed a discreprency between any image I've posted and what I viewed. I use Photoshop to process and IE 6 to view the web. I have seen a few dark images but it is impossible to tell if it was darker than the original.
You said not all photos you post show this problem. I'd gladly take a look if you provide a link to a photo which appears darker to you and email to me the original that was posted. Perhaps it is best to create a test message just for this to avoid possible file confusion. In that case, you might place a link to the same photo in the message. This would let others compare as well. This should easily determine if any image adjustment is being done by the the WoodCentral server routines. I know some forums, in particular a digital photography forum I used to frequent, do automatically process posted images for size and who knows what else.
Some other things:
- Has anyone else noticed the same thing?
- Are you using the same computer/monitor to generate and view the images? What kind of computer?
- How do you edit and view the images?
I assume you edit and view the images using some editing application before posting. Do you also view the images with some other image viewer before posting? If different, what applications do you use? Note that some applications, for example, Photoshop and others, can be configured to use a profile which is basicially set of custom calibration curves that can greatly affect the image. This profile may or may not be saved and reloaded. The problem is that the image editing program may be the only one using a particular profile! This would make things look different inside and outside the editor.
To make things worse, the computer system, printer, and even the graphics card can have it's own and different profile, sometimes called a LUT or look-up table. Add to this the gamma differences between display devices and you get a horribly confusing mess which has brought entire graphics departments to their knees! (Hardware display gamma differences between Mac and PC are a known source of problems.)
- Another possibility could be the way your specific internet browser handles images.
JKJ in East TN
JamieDonaldson
>Russ- I haven't posted enough photos here on WC to notice any file corruption, but did notice early on that WOW images I posted lost contrast and density, so I boost gamma for those posts more than I would for other uses.
Sue McLam, Orange, VT
>As a daily viewer here (never posted any pictures) I can say that MOST photos are too dark for me to see. I often temporarily copy and paste them into my photo edititing software to brighten them up. I then delete them, so please don't worry that I'm storing photos of anyone's work.
Sue
>I agree with Jamie on this. The monitor may be your problem. As for the difference Russ is seeing I'm not sure. I post most of my photos from my home computer and they look pretty close to the same on WC as they do at home. The computer I use at work is color calibrated and most of the photos look fine. I seldom see a dark photo. I see some that have much to high a contrast and some that are off color but for the most part they look pretty good.
