Have a question? Ask Woody!
Frame Problems
Frame Problems
Brad Vietje
Frame Problems
Brad Vietje
>I've set, and re-set my preferences a number of times, but I can't seem to get a no-frames view when I first log on. I'm using Windows XP Professional, and usually Internet Explorer -- who knows what version.
As currently set up, I log on, and see the Sightings frame and photo on the bottom half, and the message board at the top. Then I have to click "Add Frames" (result = two Sightings layers); then I click "Remove Frames" to get a frame-less view. I've set "no frames" as my preference, but no go. It should go w/out saying that I would click on "Remove Frames" if it were an option, but only "Add Frames" is available.
Advice, ye of computer literacy ?
Thank you kindly,
Brad Vietje
Thetford, VT
Re: Frame Problems
Re: Frame Problems *LINK*
Rick Allen
>http://www.woodcentral.com/cgi-bin/turning.pl?index
The turning forum sans frames
Re: Frame Problems
Re: Frame Problems
Don Henthorn
>Check to see what URL you are using. When I was using woodcentral.com I had the same problem. When I changed the URL to www.woodcentral.com they went away. Try it and report back.
Re: Frame Problems
Brad Vietje
BINGO ! That did it !
Brad Vietje
