Re: Carburator Trouble
Bruce in Saint John N.B. Canada
>Sounds to me like a dirty filter, probably the air filter or screen. I doubt very much if is a compression or vacuum problem as you say it starts easy so that would rule out piston rings. If the chain were too tight it would no doubt show symptoms you describe, like when the load comes on the engine it dies or boggs down. Oh must not forget the carburator, it could be dirty or your high speed mixture screw may be out of adjustment. In other words High speed air fuel ratio not correct, don't forget that engine requires (as do most gas engines) a large amount of air for combustion. Seems to me the ratio is about 8 or 9 thousand to one, in other words for every gallon of gas it burns it also burns around 9 thousand gallons of air. Good job air is not as expensive as gas, what. Hope this helps out, please let us know what you find, GOOD LUCK.
Bruce in Saint John, N.B.
