Cellulose Sanding Sealer (?) and Tearout
Peter Charles Fagg (UK)
>Friends, in the August issue of "Woodturning" magazine on page 50 in an article profiling David Nittmann he advocates using (Quote) "Mylands sanding sealer, a mixture of 50/50 lacquer and thinner" This he applies to prevent tearout.
How does this work if the coating is removed by the action of turning? Is it allowed to soak in over (A) a period of time (B) applied warm or something else that I am missing?
Your thoughts would be appreciated, Peter.
Re: Cellulose Sanding Sealer (?) and Tearout
>Peter I use Deft brushable lacquer thinned 50/50 with lacquer thinner. It penetrates the wood very far if it's punky. If it's just tearout it willusually penentrate a fair distance but as it dries it stiffens the fibers. I haven't tried it yet but I'm guessing Russ's glue and water does the same thing.
Re: Cellulose Sanding Sealer A tip.
albertabob
>Because we use the sealer for a different purpose than it was intended, it is probably a good idea to wet the entire bowl surface with thinner before applying the sealer.
This allows a deeper penetration of the cellulose and hence a sturdier finish.
I never apply it until the final sanding stage and rely on cyanoacrylate for soft spots until then.
The usual precautions apply when using volatiles.
Bob
JamieDonaldson
>I use lacquer base sanding sealer cut with a little acetone for several reasons- it stabilizes the minor tearouts for cutting or sanding, hardens punky areas, and the acetone improves penetration, drying time, and absorbs a bit of remaining moisture in the wood to further the drying process.
GeeSeaWhy
>I didn't see the article but it sounds similar to a technique Bob Rosand uses and teaches: a 50:50 mixture of sanding sealer and turpentine, brushed on and wiped dry immediately. Then you take a final light cut with a very sharp tool and the result needs little sanding. The sealer does not penetrate but it does stiffen the surface fibres and improves the cut. Just don't try sanding instead of cutting - the stuff just clogs up sandpaper.
Graeme
Ric Taylor
Ric Taylor
>I have been using that technique for about three years now, and it works great. I use a 50/50 mixture of Mylands sanding sealer and acetone. It goes on quickly, soaks into the fibers, and dries in a few minutes so that you can quickly return to turning. If you subsequently turn away enough wood that you are cutting deeper than the mixture penetrated, then you just put on another coat. Sometimes you have to do this several times.
I use this mixture during sanding too, on almost all of my projects, whether the wood needs stiffening or not. I'll sand to 180 grit, then put on a coat of the mixture. Then sand with 220, then another coat. Then sand with 320, then another coat. Then sand with 400 (sometimes another coat here if I want a really glassy surface) and continue up through the sanding grits without any more coats of the mixture. This fills pores really well and leaves a smooth surface. With a glossy finish, it adds a lot of depth and translucence. If your sandpaper clogs up badly, you have put the mixture on too heavily.
Hope this helps,
Ric
Brad Vietje
Acetone vs. Lacquer Thinner ?
Brad Vietje
>OK, Folks -- can acetone always be used as a thinner for Myland's Sanding Sealer ? I have used lacquer thinner in the past. Since Lacquer thinner is such nasty stuff to breathe and work near, I'd happily substitute the toxicicity of Acetone for anything with Toluene in it.
Advice ? Russ ?
Safe Spinning (and Sanding),
Brad Vietje
Thetford, VT
Re: Acetone vs. Lacquer Thinner ?
Mark Kauder, Phenix City, AL
>Acetone is one of the normal ingredients in Nitro Celulose Lacquer, so assuming Mylands is lacquer based, and not shellac based, you would be OK.
I use Acetone as a thinner when it gets cold. Since it evaporates quicker than regular lacquer thinner, it helps eliminate runs when I spray.
Be careful though. Acetone can attack the liver when absorbed through the skin.
Mark
James McClure
>Has anybody used alcohol to thin Mylands sanding sealer? I've been using 91% Isopropyl alcohol to thin it and it works fine for me.
RonZ
>I've used Mylands CSS 50/50 with nitro thinner [as its called here in Israel which may be laquer thinner in your area] for quite a long time. I first saw it used by Chris Stott and was impressed how well it soaked up into the wood, this is why I began using it. I used to use just plain Mylands CSS and it didn't soak in. It tried the all thinner method and then the CSS and the sealer didn't soak in well. The primary use was to hide minor scratches and flaws before final finishing with Mylands melamine or friction polish. I later found out the side benifit of stabalizing punky wood and helping to remove tearout.
Russ Fairfield
>Straight Acetone evaporates faster than lacquer thinner, and there is nothing wrong with using it if you are quick or the weather is such that evaporation is slow.
You can make your own nitrocellulose lacquer by dissolving photographic film in acetone. I have done that.
Adding more Toluene will slow down the evaporation rate of lacquer thinner.
Adding a little turpentine (pure gum spirits) will slow it down even more.
Adding a little Castor Oil will pasticize the lacquer and prevent it from getting brittle with age.
Thankyou
>Ric, your answer summs up the question rather well, thanks.
Ric Taylor
Ric Taylor
>Thanks, Mark, I didn't know about the liver problem. I guess I'll have to be better about wearing gloves.
Ric
Brad Vietje
So when does it explode ?
Brad Vietje
David Nittmann replies
>Friends following on with my enquiry and not expecting a reply I emailed David Nittmann who wrote (Quote) "Take a deep breath………… and try it,……….then tell me what you find out"
Do I take the deep breath with the cap on the bottle or off with thinners or Acetone? Could prove interesting!
