We value your privacy.
>My son was usinng my Wilton mini lathe and the tool rest broke off at the stem. Anyone have any suggestions on how to make a new one or fix the broken one? The broken one is make of cast and I took it to a blacksmith in town and he said it cant be welded.
>All you need to do is have someone weld a "T" from some round bar stock.. The new stem needs to be the same diameter as the old one. The top bar can be any length, so have a few different ones made at the same time.
>Cast iron is difficult but not impossible to weld. (Google "weld cast iron) A competent shop can weld it, or anyone can braze it. I usually fix cast iron myself with standard brazing rods and an oxy-acetylene torch, but last year I had a wood-burning stove door welded by a local shop for $5.
As mentioned, making a new tool rest from round rods (or angle iron) is relatively quick and easy. I made one for my Jet mini lathe using a steel rod to give me more length than the stock rest. It took about an hour but much of the time was grinding a proper hollow on the post before welding.
You can buy one already made. I've bought several from Best Wood Tools and they've been very high quality at a reasonable price. Link below.
>The stem can be replaced, by grinding off any edges. then drill out the base to accept what-ever diameter rod.. I drilled into the side an taped it for a set screw.
