The case for a Tormek AND a regl'r grinder
Mike Schwing from Md.
>I bought the Harbor Freight needle scaler over this past weekend to use as a texturing tool. The dozen and a half or so steel needles need to be rounded off smoothly before use for this application. My two grinders, a standard B&D 3500 rpm grinder and my Tormek, work wonderfully in unison for this task. I don't normally use a high speed grinder as my tools retain their shape pretty well after initial grinding, so I don't have a dedicated setup for it either.
So I simply dragged out the grinder and sat it alongside the Tormek, and brought out the magnifyer as well.
A few seconds on the high speed grinder, inspection for a half decent roundover job under magification, and then maybe 30 seconds on the Tormek wheel are all it takes. Without the Tormek, the surface would be rough and not very evenly rounded. With it, and its slow speed, I can progress as desired, and quick checks under the magnifyer allow me easily gauge progress. This will result in a finer finish on the needles than the high speed wheel would give me, resulting in a finer product in the long run on the wooden workpiece.
Shaping on the Tormek is interminable. Horrible. Painstaking. Like watching ugly paint dry. Sharpening on my grinder is nearly the same. Sure, I could have a nicer high speed grinder and a different wheel, but I started out with a Tormek, not the other way around.
This way, everyone is happy. Both grinders get use. The time is minimized, the final product is very pleasing and together they do what one alone could not. (IMO)
Just a quick demonstration to confirm what everyone said last week - Tormek - lousy for reshaping, wonderful for sharpening/small changes.
Re: The case for a Tormek AND a regl'r grinder
The needles
>half done.
Tormek wheel maintenance tools
>I buy a couple sets of these $10 diamond hones at the woodworking show every year. Coarse/med/fine. They last pretty well and do the job wonderfully of quickly flattening a stone. Nice that you can grind it to a particular grit, too. The diamond credit card makes for a very very fine surface, one that almost polishes the gouge.
Not good for registering it flat against a toolrest, but for gouges this is unnecessary.
nice, flattened wheel
>Maybe 60 seconds of work with one of those diamond hones.
Which needle scaler...
Paul in Phoenix, AZ
>...you buy? The complete unit or the attachment for the pistol grip handled air hammer. I'm thinking about buying one as a birthday present for myself.
>I agree 100%. Thanks for sharing the trick with the diamond "cards". I have been using a cheap, coarse waterstone (I got tired of the grading stone and I went with a less expensive option).
Re: Which needle scaler...
>The big scary looking thing. It should get to try its new owner out this weekend probably.
Jennifer@Indy.USA
>Mike you are going to love the scaler. I bought the HF as well and am having a ton of fun with it. It's an amazing time saver and leaves a very cool texture! Can't wait to see what you do with it.
Jen
