O1 Rod Sources?
O1 Rod Sources?
O1 Rod Sources?
Jorge Castaneda
>Where can a fellow find O1 Rod?
Thanks
Jorge
Re: O1 Rod Sources?
Re: O1 Rod Sources?
John Trant (Baltimore/DC corridor)
>MSC (http://www1.mscdirect.com), Enco (http://www.use-enco.com)
John
Re: O1 Rod Sources?
Thanks John!
Jorge Castaneda
>Much appreciated.
Jorge
Re: O1 Rod Sources?
Re: O1 Rod Sources *LINKS*
>I get mine from Bohler-Uddeholm, through their on-line outlet, FlatGround.Com.
FlatGround.Com
It is also available from MSC, Enco, and McMaster-Carr
MSC search for Oil Hardening Drill Rod
Enco search for Oil Hardening Drill Rod
McMaster-Carr under Raw Materials, select "Metal", then "Steel", then "Rods and Disks", then "Drill Rod", then "O1"
Re: O1 Rod Sources?
>Enco has occasional sales of Drill rod and it's really inexpensive when they do. You might ask if they have any sales flyers out if you call them.
Re: O1 Rod Sources?
Jorge Castaneda
>Thanks William,
I printed already and saved in a couple places,
much appreciated.
Jorge
Re: O1 Rod Sources?
Thanks John
Jorge Castaneda
Re: O1 Rod Sources?
>You know this stuff is sold in a totally annealed state (SOFT!), right? After grinding a channel and an edge, your next trick will be figuring out how to properly harden and temper it. Of course, that's the advantage to using O-1. You can easily build a setup in your own shop to harden it.
Re: O1 Rod Sources?
>I get their e-mail fliers, but so far haven't seen drill rod on sale. I'll have to watch more closely. IIRC, they also have a button on their home page that will take you to their sale items. BTW, this month they are offering free shipping on $200 or more of items purchased via the web. That would buy a lot of drill rod :^)
Re: O1 Rod Sources?
Jorge Castaneda
>Yes William,
I am aware they come soft and I have made quite a few tools in the past, so I am familiar with the hardening and tempering process. I have a little knock down set up of fire bricks.
Thank you!
Jorge
