200+ woodworking book reviews
turning blanks
turning blanks
turning blanks
Dave Midkiff
>Thanks for your response JL. If I cut 2" or 3" above the crotch and 5" to 6" below the crotch I would have a blank 7" to 9" with a diameter of the limb. In your opinion, would that give you enough wood to turn a nice bowl?
Thank you,
Dave
Re: turning blanks
Re: turning blanks
Gary Evans Tallassee, TN
>Hi Dave,
I would add an extra couple of inches in each direction. That way if you get a little checking, you can still get a good sized finished piece from the blank. Do you have anything available to seal the end grain? If you are splitting the crotch, it's also a good idea to put some sealer on the crotch grain as it will want to check there, too.
Gary
Re: turning blanks
Re: turning blanks
Dave Midkiff
>Thanks Gary,
As you see I ended up with 2 posts. I will give it a try.
