some many chucks out there
Kevin Turner
>Okay, for the folks that have a lot of experience in turning this may some silly. I would like to know, what type of chuck should the beginner think of purchasing... Up too this point all turning are completed with a 6" faceplate and friction fit plates made of MDF ( on the 6" faceplate)I read the past entries and looked up the link provide. But I'm not sure what to look for...i.e quality..I also saw the entry about Barracuda , then the question about the Grizzily . Please point me in the right direction...Thanks, Kevin T in T Bay
Re: some many chucks out there
The chucks I have used....
Bert
>I'll confess that I have not used every chuck out there, but I currently own these three:
1. Oneway Stronhold
2. Vicmarc 3.5"
3. Nova
They are all fine tools but if I had to choose a favorite it would be the Vicmarc. The Stronghold has more capacity but the mechanism seems easier to work on the Vicmarc. -small difference for sure.
The Nova is nice because it is smaller and thinner than the others but the "tommy bar" control can be tricky one handed.
If you haven't been working with a chuck I think you will be thrilled with whatever you get. It simplifies everything including the use of jam chucks. I have several pieces of ash, maple cherry and even MDF that have either recesses or dovetails turned on them that are always being customized for use as a jam chuck for bowls, boxes, pepper mills etc.
Good luck and happy turning.
Bert
Re: The chucks I have used....
Carole in VA
>I'm just a beginner and far from experienced, but I really like my Supernova2. No tommy bars and a good grip. But then I haven't used any other chuck except the Nova Midi (the new one, not the Compact) I debated over some other chucks but then Woodcraft had the Supernova2 on sale. :)
I like tommy bar chucks
Brian Hahn in SW Wisconsin
>Many people don't like tommy bar style chucks, but I prefer them. They open and close very fast so you can get a snug fit in seconds. Then, if you choose the right holes, they can easily be tightened with one hand to any desired force. (I've split the tenon off of a hickory bowl.) You'd be surprised at how much strength you have in your grip!!
>Kevin I have the new Grizzly, the vicmarc 100 and an old Nova Tommy bar style. They all work but I like the vicmarc the best. If money isn't a major issue you can't go wrong with the vicmarc or the Oneway Talon. If you'd rather not spend that much then the Grizzly is a close copy of the vicmarc and works great.
Personally I like the tommy bars for some things as well. They are very fast you just have to work out a way to lock one bar against the lathe or use your spindle lock to get the chuck snugged up and then use the other tommy bar to tighten. I have occasional boughts of arthritis in my wrist and when that happens it's much easier for me to use the tommy bar chuck than the other style.
