display for plates
display for plates
display for plates
gary clarke
>I am looking for a way to display plates/platters and would like plans for making a wooden easel. Any other ideas would be appreciated. thanks
Re: display for plates
georgetroy
>You could go to the framing areas at Wall-mart, Hobby Lobby or such and get some of the stands there. They look like they were done with a scroll saw and are hinged. To make your own just trace on wood and cut out, from there you can develop your own ideas. You will need some metal hinges or make leather hinges. GT
One Possibility...
Peter Teubel
>I found this design somewhere (probably here). Haven't tried it out yet, but it looks pretty good. The main stem is slightly tapered (I suppose one could turn it, too) and the legs are dowels. I vaguely remember the person who made these actually purchased 1" wooden balls for the ends because they were so cheap and it would take more time than its worth to turn them. One of their selling points was the fact that the stand was included with the purchase of the palte/platter so the customer could display the piece as they saw it when they bought it.
Re: One Possibility...
Mick, in The Bahamas
>I BOUGHT SOME METAL ONES FROM Bed Bath & Beyond for about $10 ea. They are antique brass and wrought iron look, but when a platter is on them they are very unobtrusive.
Mick
>Peter I love it, simple and turned. Here is another possibility. www.tripar.com They all kinds of display merchandise.
Bill Neddow
>Gary, I am the one who posted the picture Peter found of a plate stand. It is in my gallery over at WoW -- but for those of you who do not belong to that site yet, I can give you some basic info. They are really easy to make. The upright is simply a piece of Maple or whatever hardwood I have. I cut a slight taper on it to keep it light at the top, yet substantial enough at the bottom to give it strength. This I do on my table saw. I cut a wedge of one or two degrees on a board and put it up against my fence. Then I can run the pieces of upright through quickly and get a taper. I cut a year's supply (20-30 pieces) in less than 10 minutes. Save one of the offcuts to make the piece of wood "square" again when you go to drill the holes in the bottom. I use 5/16" inch dowel, because that is what I generally have around the shop of other purposes. These pieces have to be custom cut for each platter as the deep ones take longer dowels that the shallow platters. The balls come from Lee Valley, because their store is close by (very dangerous place to go!). I think Michaels also sells them, as do all the toy part suppliers around the country. Make sure you put them in a small vice, and punch a starter hole for the drill before trying to drill them. (I have heard Michaels has them pre-drilled, but I have not checked yet.) The balls can be stained or painted to match a highlight on the platter, if you wish. They really help sell the larger platters. Most people who would like to buy one do not have a spot to store a 20 inch diameter platter (most of mine range for 16" to 22"). With the stand, they can leave it out on display on a sideboard.
gary clarke
>thank you all for your generous help. Hi ho its off to the shop I go.
