turning green pen blanks
John Coco
>I have a piece of comphor burl and intend to use it in a new hobby that im just getting into, pen turning. However the wood is supposed to be (green to partially air dry). What do I need to do to make sure that the wood does not crack after I turn it. Or should I have to wait for it to dry about 6 months before fooling with it. My turning skills is limited to a a few spindles and a chess set, and this is my first piece of wood that is not kiln dryed.
Thanks for any help.
Re: turning green pen blanks
Jim Ketron
>I have been using the DNA alcohol method with good results.
Leaving them in for 24 hrs, then letting them dry.
Jennifer@Indy.USA
>John, there is a lot of great information here and I will give you my 2 cents worth. When turning pens you really need to make sure that the wood is dry. If you don't it will usually crack off of the brass tubes. I'd hate to see you work hard on a nice pen and then have the wood shrink as it dries and crack up. The DNA that Jim is talking about in the post below is Denatured Alcohol. Soaking the wood in the DNA and then letting it air dry has been found to dry the wood quicker than just waiting for it to dry on its own.
Hope this helps,
Jennifer
Dry it in the microwave oven.
Clem Wixted
>There is a lot of information on this technique for small pieces. Do a search and you will have plenty of reading and good information.
Don't overdo it or you'll burn the wood. It usually isn't very tasty after it's burned :-)
Clem
Ron in Drums PA
>I've used the DNA method, previously mentioned, on pen blanks with success.
