Some More Instruction
Ben Aragon
>Some More Instructions
John,
Here are some modifications and tips that I hope will help.
1. Who ever is in charge of the work shop needs to have electronics back ground either a technician or engineer. There is dangerous high current inside these PS.
2. I soldered up all the boards days before the workshop, it was a lot of work but I’m glad I did. It is a delicate job working with that Datak proto board. At the work shop it was difficult for some to solder the switch without melting it, it’s not their fault. From start to final test on each proto board it took about 45 minutes. Yes check each board with an oscilloscope.
3. Open the PS look to see where you can mount the switch, pot, RCA jack, lamp, and board. I mounted the board on the fan of the PS, I’ll post a photo later. Remove the PS’s main board, blow out the dust and drill your holes. Remount the PS’s board.
4. Cut the connectors off all the wires and separate them by color.
5. Mount and connect the 12v lamp to a yellow and black wire. Mount the RCA jack and pot.
6. Use a PS that has an ON/OFF switch. Cut the old switch off and solder the wires to the new switch and mount the switch. (Switch, blue to white and brown to black.) Test PS, see if it turns on, if not add load resistors. If it still doesn’t turn on scrap it. We mounted the load resistors under the cover.
7. I used a 10 turn pot instead of a 1 turn pot. The 1 turn pot came to full power at ¼ turn the 10 turn pot came to full power at 2-1/2 turns, better dynamic range.
8. I didn’t use a heat sink on the MOSFET, it is rated for 60 amps and I think at most this pen is pulling 3 amps.
9. Connect 12V and 5 V lines to the proto board and MOSFET and mount it some where in the PS. Connect the MOSTFET to the RCA jack and the proto board to the pot.
10. Turn the pot fully CCW, connect the pen and test the PS.
Skill levels of our participants varied but all were mechanically experienced and everything got done.
The pen building is another project altogether.
Look at this website for a start on instruction,
http://www.fishcarver.com/making_fish_scale_tips.htm
And
http://www.fishcarver.com/images/burning%20instructions.PDF
Or buy pens already made I really like this guy’s pens. We built ours like these where the tips are silver soldered to the pen for a much better connection.
http://www.carvertools.com/frmain.htm
I scheduled the work shop for one Saturday day. It took me all day Thursday to make 16 proto boards. Friday I finished them and proto typed the pen design easy day. Saturday 10 people attended the work shop and we built most of the 16 PS, all the pens and pen cables. Sunday 4 people returned and we finished the PS and we had 12 working units at days end. The rest of the week M-F I repaired 3 of the 4 that didn’t work and had to completely build a new 4th.
Have fun and my Best Wishes,
Ben
PS email me if you have questions I’m sure it’s clear as mud and I may have forgotten a few things.
