gap distance for lids?
Kevin Turner
>For those who have turned bowls with lids, What would be the appropriate gap distance? The bowl is segmented with Black ash, local birch, mahogany. Thank you, Kevin T in T Bay.
p.s. its' been humid here in T Bay.
Kevin Turner
Re: gap distance for lids?
>Kevin Sorry no one has answered yet. Is the top segmented also? If so the movement is less predictable depending on how you put the pieces together. If you put them toghether with the the grain all oriented the same way then it is more predictable. Wish I could give you specifics but without a lot more information it's tough. What I do when I'm not sure is to leave plenty of room and then design the joint so the gap is concealed. You may still have a loose fit but any gap will be covered.
If you glued up the segments in small pieces and with grain running in all directions then it will act like plywood with verually no movement. Then you can leave almost no gap.
If you search you should be able to find an article on wood movement that will give you some idea of how much each piece of wood will move. I believe Wood magazine had an article on that a few years ago. John Jordan has a great DVD on wood movement but it's geared toward solid wood. He does cover the basics very well. Jack Cox's book on segmented turning mentions wood movement in various places but it's hard to decipher. Malcolm Tibbets book on segmented turning discusses wood movement a little but mostly states that the grain should be running the same way all the time.
Just to give you a ball park idea a 12 inch plain sawn board will move about 1/8 to 1/4". This covers a lot of species. A quarter sawn board will move less.
