I Think My Bandsaw Needs A New Motor
George Balock
George Balock
>On Monday I was cutting some osage blanks with my 14' Jet bandsaw and it was having the hardest time. I changed to a brand new Timberwolf blade and still having a time. The motor got hotter than heck and would barely cut. Is it time to replace the motor? If so with what? Thanks in advance.
George
Re: I Think My Bandsaw Needs A New Motor
Phil Lieberman
>with a Baldor motor from amazon.com! I did it to my Jet bandsaw a few years ago
How many horses?nm
David Galloway
Re: How many horses?nm
vicmarc.fan
>I use my saw just to cut green wood now. I have a 14" Delta that has the riser and had a 1HP motor. I used about every blade on the market but still had problems. What I did really made a difference. I replaced the motor with a 2HP 220volt 1750RPM motor. The reason I went with the 220V motor was so that I didn't have to run heavier wire to a high amp. 110V motor. Just changed the plug in. 220V cuts the amps. in half. A famous woodturner in Colorado added a 3HP motor to the same saw but it wouldn't fit where the origional motor was. Too large for the case. I have no idea if the extra HP makes that much difference, going from 1 to 2 sure did.
George Balock
George Balock
>The Jet stock is a 1 HP and I would like to go to at least a 1.5 HP motor. How are the harbor freight motors? I don't want to break the bank on a Baldor.
George
Phil Lieberman
>HF Electric Motors are junk! Big time mistake. Now i think i paid $179 bucks free shipping for the Baldor 1 3/4 hp 1725 rpm it might be the 1 1/2 hp but its like night and day.
Re: dont forget the link belt!!!!
Phil Lieberman
>And your going to need to drill out the stock holes on the bandsaw mounting plate to make it fit. Hope it helps i could take a picture if you like and send it. Phil
>One thing to make sure of, even with a sharp blade, is the tension. My 14" Delta with riser cuts thick wood fine AS LONG as I get the tension high enough. If the tension is too low, the blade will try to bow in the wood which will create a great deal of drag and probably stop any motor (or break the blade).
I understand the springs tension guage on the back of this type of bandsaw is very inaccurate, even when the spring is new. It gets worse with age as the spring fatigues.
With a relatively new spring, I still have to keep the tension higer than the guage recommends. For a 1/2" blade, I set it to the 3/4" mark. Note that you can crank it too far: if the spring is compressed all the way there is no "give" to take up shock and allow for small variations in wheel roundness. The books warn that this can damage the saw and/or blade.
JKJ in East TN
>I forgot to mention - the blade should also be compatible with the thickness of the wood. Even a very sharp new blade with two many teeth per inch will clog up and bog down when cutting thick stock.
JKJ in East TN
George Balock
George Balock
>Phil,
Thnaks for the warning on the HF motor. Where did you get the Baldor? And if you get a chance e-mail the pic. In much appreciation.
George
I have some experience with this....
Dominic Greco at home in Richboro, PA
>George,
About (2) years ago, I replaced the 1Hp Motor that was in my old Jet 14" bandsaw with a new 2HP Baldor motor. The details of that are covered in this article:
Jet bandsaw Upgrades
Take it from someone who has replaced more than their fair share of motors (I replaced motors on 3 tablesaws, on a 6" Jointer, a shaper, a dust collector, my 14" bandsaw, and an old Sear's jigsaw) bite the bullet ONCE and buy a good one. Baldor is the best. Marathon, Leeson, and Reliance are also good (and are more economical). But I prefer Baldor.
Are you're going to attend the Cindy Drozda class at Dave Hardy's on Sept 25th? If so, we can talk about this then.
See ya,
Dominic
Keith Newton
>On the BIG commercial side, firms like Tannowitz supply them with motors that ~= 1 hp for each 2" of thickness capacity, which seems about right to me. I had a 5 hp on a 36" saw for about 15 years, and finally replaced it with a 7.5 hp about 3 years ago. I wish I had done it sooner. I only have 16" under my top bearing of height, but the big tannowitz brand supplies them with a 10 hp, but they can cut 20" thick.
Re: Sent!!! Check your mail
Phil Lieberman
