A55 Smoothing Plane
Better Banjo for 3520A
Dan in the NW
>Has anyone replaced the banjo on their PM 3520? I have 5 or 6 tool rests for a Jet 1642. Unfortunately the posts are a bit on the short side. The PM 3520 banjo is shorter than most banjos for a 20" lathe. As those of you with 3520s know it adds a bit of fun to the toolrest search.
I've considered a couple of options. I could have a machinist ream out my existing banjo and put a machined extension collar that brings it up another 1' to 1 1/2". The other option was to have the bottoms of my tool rests drilled and tapped to take an extension with a set screw countersunk to keep it from coming loose. I've also thought about making my own tool rests.
All three ideas are doable. But I started thinking about the advantages of having a second banjo. For long spindle work I could build an 18" to 24" tool rest and support it at both ends. The second banjo could hold my captured hollowing rig and I could get rid of the funky wooden support I built. When I build my steady rest, the second banjo could hold it in place.
I've looked at and used the Oneway banjos. They seem to work better than other banjos I've used. Oneway sells them as a retro-fit part for other manufacturer's lathes (http://www.oneway.on.ca/lathes/non-oneway.htm). At $225 it's not a prohibitive cost. I could easily spend that much on the other options.
I'd be interested in hearing from anyone that has put a Oneway banjo on a PM 3520. Also, convince me I going to wrong direction or what other options you've considered.
Dan
(x's in email address are not needed)
Re: Better Banjo for 3520A
Gary in Zirconia, NC
>I think the Oneway is the best choice. I have a General on my 3520a as a second banjo to hold a captured system and as a bowl steady and it works, but it is too narrow and if turned parallel with the bed, it drops between the ways.
Norm Smith in Nova Scotia
>Dan, I have a 3520a and had some extra tool rests that had posts that were too short. I cut the post`s off and replaced them with longer post`s. The cost of getting a longer post welded on was cheap. Don`t extend your post because the joing will joint will catch when putting it in the banjo.
Norm
>I'm perfectly happy with my short banjo on the 2035. I like to lower the tool rest for some cuts. www.bestwoodtools.com has tool rests that fit the 2035. I bought some old Delta tool rests that were too short. I welded on an extension made out of 1" drill rod.
You can't go wrong with Oneway...
Peter Teubel
>A few years ago, I bought a 1224 banjo & tool rest for my Jet 1236. Best thing I ever did for that lathe.
