We value your privacy.
>I salvaged a holly tree from a neighbor yesterday right before it was going into the tree service's chipper. It had a 14" base and most of the trunk is 12-11". Now I have a driveway full of bright white holly, some large wild cherry, and hickory.
A search of the archives shows there has been a good amount of discussion on how to keep holly white. Soaking in bleach, fungicide, etc. I am cutting most of it into blanks this morning, so it will not be exposed to dirt, sun, etc. Most of the threads were six months or more old. I'm wondering what is working best?
>I am not an expert but I have handled a lot of holly. Last spring I had some hugh blanks. I turned them per Dave Smith's instructions and soaked in denatured alcohol. The wood remained white and dried without too much distortion. I was also faced with the problem of finishing a 16" holly salad bowl so it could be used and still have it remain white. My usual Velvit Oil finish would yellow it.
I have experimented with using the Velvit Water Based Poly with good results as so far as keeping the color white. The poly was thin enough that I could get penetration. I wiped the extra off of the surface to avoid a shine. That was as far as I got. This summer has not been too productive with turning.
>Holly has always been one of my favorite turning woods, and I have cut up trees on East, Gulf, and West coasts; but it has always been a wood of surprizes for me. I think I have done everything that has ever been recommended to keep it white; but no matter what I have done to it or how it was stored, the Holly has always had a mind of its own.
There are 4 things that will happen to the Holly. It will develop a beautiful black line spalt in white wood, it will turn into a uniform light brown color with maybe some grain accent and small areas of the spalt, it will stay white, or it will just lay there and rot. Staying white has always been the most difficult to predict. All 4 can happen in blocks from the same tree that were handled and stored the same way, and sometimes all 4 will happen within the same block.
My best success in keeping it white has been to reduce the tree to lathe-ready blanks, or whatever other ready-to-use shapes, as soon as possible. These are then totally encapsulated with a sealing wax, and then stored in the coolest and darkest corner of the woodshed.
Others will have different experiences with Holly. That may have something to do with being different species, local climate or soil conditions, phase of the moon, or any number of other variables. For me, I have had fresh cut Holly in blocks in several geographic locations, some wild, some from orchards, and various ages and diameters. All of the trees looked the same to me, and it all behaved the same way. Whatever I get is always fine with me because it will all look good when finished. If I want white Holly, I can go to lumber store and buy it.
I have never found a finish that will keep White Holly a true white color. Other than bleaching, it will always turn into a color that is similar to that of old Ivory. The only difference between finishes is in how long it takes to get there and how old the ivory that it looks like. Even polished bare wood will turn that same color, and faster than finished wood because the finish offers some UV protection. I have never been concerned with it turning color because Old Ivory looks good to me.
Others may have better luck with keeping it white, either in the wood or with the finish.
>I did a 14" vase out of holly a couple of years ago. From experance I knew that Watco would turn the holly yellow. So when the time came to put a finish on the vase I just buffed it. I stayed away from the tripoli bar and just used the white diamond and the carnauba wax. So far the vase has stayed white.
Thanks for the info! In addition to your four things that can happen to holly, a fifth thing I have observed is that it becomes a dull bluish grey. This is what I want to avoid. Maybe this is a precousor to spalting.
I am familar with the aged ivory color and I like it too. I cut about half of the logs into rounds today and will get to the rest tomorrow. I would be thrilled if some of it spalted. I'll seal about a half of the remaining logs and stack them under my deck, under which everything spalts.
>In some holly there will sometimes be a slight grey color to the heartwood, that is natural. What you are talking about is blue stain. Holly will stain very quickly sometimes.
