Pin Oak for turning?
Joe Pack
>I am a very inexperienced bowl turner...really NO experience. Due to our late winter ice storm, I have all the "practice" wood I can play with and burn for a long time. A friend has some 18-24" diameter sections of pin oak I can have (same storm). Should I pick up some of this pin oak? Does pin oak, or any oak for that matter, make good bowls, etc.? Is the wide, open grain a problem?
Re: Pin Oak for turning?
I like it...
David Propst
>Hey Joe,
I love turning green oak and also love the way it sands and finishes. The downside is the dried bowls are tough to cut, but tearout is rarely a problem with sharp tools. Boiling seems to help prevent the checking, but still expect to lose a few. If I get cracks that are manageable I fill them with charcoal or walnut dust and CA glue.
I finished an oak bowl yesterday that had lots of character. I'll post a pic later today, it may end up in the benefit auction.
David
Carole in VA
>Turns nice green. I use boiling and alcohol, but be sure it is really dry before you finish turn it cause it definitely will move on you. As Dave said, it's pretty hard when dry, but sharp tools can handle it. I personally don't mind the smell so much, but one of the nicknames for the stuff is "piss oak" if that tells you anything. :)
JamieDonaldson
>Carole is right about the smell- make sure to move the shavings out of the shop immediately after turning, or you will regret opening the door next day!!
