Golden bowl
Golden bowl
Golden bowl
Ed Kelle
>Small cherry bowl, about 5" or so. Random cuts in the rim done with a small saw, textured with my Dremel, stained ( yes I used the S word here) with an Antique English stain, then given gold leafing inside. Not the real gold, but the affordable kind.
I think the gold really sets a nice contrast from the outside texture as well as the inner colorings, while the cuts make this appear to have a ceremonial function.
Yes I am slowly developing a direction in which to take my works. Enjoy!
Re: Golden bowl
inner photo
Ed Kelle
>This shows the gold leafing a bit better. Foil was then coated with many coats of Spray on Matte Varnish that I used on oil paintings.
Re: Golden bowl
That's cool.
>I really like that piece. The texture, the cuts and the gold...it's all good! Very cool.
Tommy
Re: Golden bowl
Re: Golden bowl
Ben Aragon
>Ed,
I really like the bowl, the form, texture, color, and the patina on the gold leaf, I not sure I like the cuts. Great job.
Ben
Re: Golden bowl
Re: Golden bowl
Molly Winton
>I like this a lot Ed. The texturing in particular is wonderful. The cuts add a unique touch to it.
Re: Golden bowl
Re: Golden bowl
Jim Shaver - Oakville, Ontario
>Hi Ed,
I like this very much!
take care,
Jim
Re: Golden bowl
Steven Antonucci
Bowl, yes. texturing, yes, leaf, yes- cuts,...
steve antonucci
>not so much.
great form on the bowl. And I absolutely love the texturing- what bit do you use? I've never been able to get that effect?
Steve
Re: Golden bowl
Re: Golden bowl
>Ed Wonderful job.
Re: Golden bowl
Re: Golden bowl
Barry Turner
>Very striking and unusual. I like it!
Re: Golden bowl
Re: Golden bowl
GeeSeaWhy
>I like everything about it except the saw cuts. They don't fit in with the texturing or the form. My first reaction was to find a way of making the cuts less regular but I can't come up with anything that would make them look like they belonged there.
Graeme
Re: Golden bowl
Re: Golden bowl
Mike Schwing from Md.
>Ed, I am really impressed by this work! The texturing and the applied finish look really, really nice. The cut lines for some inexplicable reason are in conflict for me. Nonetheless, this represents great talent and ability!
Re: Golden bowl
Thanks guys
Ed Kelle
>The bowl sure was an adventure for me. Here's what happened... I returned the roughout after drying, then about a day later I noticed some pith cracks, one each side both going in the same direction and about the same size. For a few days I sketched on the bowl to see if I could carve something to remove the areas, but never was satisfied with what I came up with. I figured that this bowl was probably a goner so I decided to experiment a bit so I cut right thru the cracks, it was suprising that they happened to line up. I wasn't totally satisfied so I ran blue tape around the outside to give myself a depth line then continued with more cuts at random angles, sometimes going thru both sides with one cut. Did I bunch of these and still wasn't sold on the idea so then I considered cutting out areas between the slots but decided to just texture the outside.
I use the small diamond bits in my Dremel. There is a set of about 15 for $20, they seem to work fairly well but still you get some slight scratching in the holes. I finished a few hours later after going over and over the whole surface with 3 different round bit. No matter what speed of how easy I went with the bits, I seem to usually get some burning on the endgrain. Even though I cleaned the bits very often on one of those rubber sanding belt cleaners.
So I decided to stain it to hide the burns like I have done before. The idea for the gold came from Mikes bowl the other week. I wanted to make it look worn so I used a foil kit. Worked fairly well. then sealed with spray matte varnish.
So I learned a bunch from this piece that I thought was a throwaway. I'm pretty happy with the results. The cuts might not fit in with the whole piece, but they do manage to add a bunch of contrast and even some conflict to it which at least provokes some thought.
If I continue cutting into bowls, I will try to plan it out more, but I've always been someone who develops things on the fly. I like taking risks with works and the adventure from that is more important to me than the outcome most times.
I'm having a bunch of fun with all of this and getting lots of ideas from all the great works I see here
Re: Golden bowl
Taking (safe) risks
Jack Savona
>Taking (safe) risks = ___________________.
Re: Golden bowl
Keith Tompkins
Re: Thanks guys
Keith Tompkins
>Hi Ed, nice work....it's fun to experiment with new techniques, then apply what you learn, and what you like to the next piece.
