Joaz Shear Scraper
Joaz Shear Scraper
Joaz Shear Scraper
Bill Stehman
>Joaz, thanks much for the thread on your scrapers. I had a drawer full of old roughing gouges that have never been used so I began to grind and grind. One at 30 degrees, one at 45 and another at 60. They do have to be presented a tad lower of center. A great use of an unused tool. As being a shear scraper that would have to be debated for the rest of time as Mike Schwing just showed using a winged gouge riding the bevel and making shearing cuts is what a shearing cut is. I can achieve very nice shearing cuts on these reverse grind tools but only on the shaollow cut 60 degree tool. I got very aggressive using this cut flat on the tool rest with no catches. Maybe because of the round over of the roughing gouge. In any case, thanks much for sharing and I will keep playing...
Bill ... AZ
Re: Joaz Shear Scraper
Juergen
>Compare the shaving created by the two tools if they are the same, then they are both shear cutting.
joaz
>Yes, the more the angle the more aggressive the cut. I also use the shallow tool much more then the deep one. I have also used a very small one for inside boxes and such.
The large massive tool can also be used to hog out material from the inside center.
This is a great tool to have
in the the arsenal and I am glad to hear all this positive feeback.
Here is a new mallee bowl within a bowl.5" dia 3" tall
Happy bowling!!
