shear scraper
shear scraper
shear scraper
joaz
>Hi folks, there has been a lot of questions and interest in the shear scraper I use on bowls so I thought I would post some pics of how they are ground and what sizes I use.
The large one the bottom is a 1 1/2" spindle roughing gouge and the smaller one
] is a 3/4" roughing gouge.
I have had a lot of positive feed back on these tools for eliminating tear out on both the inside and outside of bowls and spindle's.
Any questions??
Re: shear scraper
Re: shear scraper
joaz
>Here is the top view of shear scrapers.
Re: shear scraper
Re: shear scraper
Jonathan Spool
>Those look quite interesting. I have a large roughing gouge I hardly use, and would like to re-grind it to your shear scraper configuration. I'm set up with a wolverine jig w/varigrind.
Any suggestions as to how to proceed with the grind, and tips as to how you use the tool?
Thanks
Jonathan
Re: shear scraper
Re: shear scraper
Ben Aragon
>Very interesting looking tools could you elaborate a little on how each one is used and in what circumstances they work best or worst.
Thanks for the posting,
Ben
Re: shear scraper
Re: shear scraper
Joel Hunnicutt
>I Knew someone on the board had given me the suggestion and I couldn't remember who.
I ground this tool a few months ago and it is the best fine shaping and finishing tool I have ever used. I'll now know who to give the credit to. Thanks!
Re: shear scraper
Re: shear scraper
Don Orr
>If you could, please provide a few more details as to useage. For example, flute up or down, angle of attack, etc. Maybe this will end up widely used and known as the " Joaz Finish Scraper" or the " Joaz Grind".
Re: shear scraper
Re: shear scraper
joaz
>Thanks all, I will post three pic here to help explain.
The first is the grind. The more angle the more aggressive.
I like a 30 to 45 degree angle which is very aggressive.
Turn the tool upside down on the grinder tool rest after setting your angle.
Sharpen the sides first by sweeping a long cutting edge as far down both sides as your set up will allow.
Merge the two sides with the nose.
Be sure you have a good wire edge.
Re: shear scraper
Re: shear scraper
joaz
>This pic shows the tool being worked on the inside. You can pull or push but is best you get used to the pulling from the bottom before trying the push cut. You can also concentrate on small problem areas of torn end grain.
With a tool this wide, set you tool rest back a bit so the tool does not slip off the rest.
Keep the handle up as you would with a regular scaper.
You don't have to push or pull hard, let the tool make fine curls off the wood.
Re: shear scraper
Re: shear scraper
georgetroy
>Thanks Joaz you have made it all very clear. I have some old gouges around that should make some good scrapers in this style. GT
Re: shear scraper
Re: shear scraper
>Do I see you cutting below center here? When you say "handle high" do you mean higher than the cutting edge and if so how much of a slant (5, 10, 20 deg)?
TIA
M
Re: shear scraper
Re: shear scraper
joaz
>This pic shows the tool working on the bottom outside.
This is a little harder to explain so please bear with me.
Pull the tool at an angle across the wood. You are pulling towards the rest but the only part on the rest in the outside bottom of the tool. This is very similiar to using a regular shear scraper but not as scary.
As you come down, you come back flat on the rest and work the rest of the way around the bowl with the tool flat on the rest and the handle up.
You can only get in so far on the bottom with a tool this side.
I have other smaller scrapers that will allow me to get closer in and perhaps be able to shear with the smaller scraper in the flat position.
This looks scary, but with practice, you will never go back to you 60 grit gouge to clean up end grain.
Re: shear scraper
Re: shear scraper
joaz
>Yes a little below center. 10 to 20 degrees. You will feel it start to shear.
Re: shear scraper
Re: shear scraper *LINK*
joaz
>Her the scraper is on the out side with the tool flat on the rest. Just pull it along and you will see and feel the shear.
On the oustide i generally work from bottom to top edge.
Again, keep your tool rest set back to keep from slipping off rest.
Smaller tool can be worked closer.
I hope this helps explain this tool.
If not, go to my web page for more detail.
Better yet, sign up for my woodturning class(before the snow flies)
Thanks Joaz
http://www.maine-web.com/woodturning
Re: shear scraper
Re: shear scraper
Jonathan Spool
>Thanks! That was all very informative.
Jonathan
Re: shear scraper
Re: shear scraper
David Campbell Upland CA
>I first saw this type of scraper being used by Jim Christiansen at the Ontario CA. Woodworking show three or four years ago. I find it excellent for smoothing the inside of bowls and am just waiting on time and money to add another gouge or two to the collection. The one he used was from a continental type of gouge which had a smooth and shallower curve than most roughing gouges. I had not tried it on the out side so will have to add that to the items to try.
Re: shear scraper
excellent idea
>I have just the gouge to try this on - a wide shallow HSS gouge out of a cheap set from Sears! It will be interesting to compare it side-by-side with a rounded scraper. Thanks for sharing.
JKJ in East TN
Re: shear scraper
Sean Troy showed one 2 years ago. I need to try it
Dave Smith, Longview, WA
Re: shear scraper
Re: shear scraper
Don Orr
>Joaz-thank you very much for the excellent photos and decriptions. I think you get the point across very well. I don't have any gouges that big but I'll look around at garage sales and such.
Thanks again!
