photographic paper
gary clarke
>I have found that blue fleece from any fabric store works well for background in photos. It comes in many colors, but I like blue which works for me and you do not have to iron it as it is difficult to wrinkle.
photographic paper
gary clarke
Re: photographic paper
Gary Ljostad
>Just a word of caution when using any blue background. Often blue is reflected onto your turning and it gets a blue cast, which can ruin a great picture.
JamieDonaldson
>Thanks Gary, you saved me from having to dig out the BLUE WOOD speech!! Fleece also has too much texture for turnings- detracts from the central subject matter.
Pat Mulligan
>I got a roll of rosin or building paper at the lumber yard.It cost 12.00 and is neutral gray and is very long.A cheap solution for my photo backdrop.
Could you past examples ?
Brad Vietje
>Gary and Pat -- to aide the discussion here, could you submit photos that show these backgrounds in use ? A simple bowl or something, shot against these backgrounds, would help a lot.
Safe Spinning,
Brad Vietje
Thetford, VT
Re: Could you past examples ? pic
gary clarke
>I will send a few pic
gary clarke
gary clarke
gary clarke
gary clarke
gary clarke
>blue wood, pic speak for themselves? some wood may turn blue, but I have not had any yet :)
>Gary I have to disagree the bottom of each vessel is blue. I won't agrue against the blue because we all have different tastes. I think the problem with the gray is that it is too light a color for those pieces. If you took away the color you would notice the blue is much darker in relation to the piece. I think if you used a darker gray or if you shaded the background so the tones would go darker toward the top you would have a really nice photo.
Then turn the camera vertical for some of the shots so you would fill the frame. This way the background sort of dissapears. In your photos I keep wanting to look at the background because there is so much of it and the color is so dominant. That's just my opinion but it comes from 16 years of shooting art work.
gary clarke
>John, thanks for the tip. The road to success is always under construction. I will try different colors of fleece and experiment some more with each pic.
Ron in Drums PA
>Yep, the bottom is blue all right.
JamieDonaldson
>And as a pro for 39 yrs. I can verify what John is saying is correct- that is definitely blue wood. A few of the lighter colored wood pieces could have shown up better against a darker background, like black, but the ideal for demonstrating wood to best advantage is to enhance the contrast between subject and surroundings. If the background is similar in color density(gamma) to the object, the contrast is similar and not very dynamic. And if the background is competing for viewer attention by distracting from the subject matter,the object is diminished. Test an image by squinting your eyes during viewing- does the subject or the background stand out? Exposure adjustments don't resolve the problem, but digital manipulations of hue and saturation can improve the image somewhat, corrections that were not so available on film.
