Dawn Redwood! *LINK*
Rick in Colgate, Wi
>I was given some large sections of a Dawn Redwood tree that was taken down. The wood and bark are similar to cedar, with the heartwood being very reddish in color. Should be interesting turning some pieces out of it, however, the wood is very soft.
The tree has an interesting history!
http://www.icogitate.com/~tree/dawn.redwood.timeline.ac10.htm
Dawn Redwood Tree
Re: Dawn Redwood! *LINK*
Re: Dawn Redwood!
>I haven't had any of the wood but I love the tree. There are a lot in this area, some that look to be 75-100' tall. I planted one a couple of years ago at the end of one field and it's doing great.
If you want to sell a few 2" squares for spindle turning I'd be interested.
JKJ in East TN
I cut one down about 10 years ago.
Dave Smith, Longview, WA
>When I built my shop I cut a dawn redwood tree down. It could be use as balsa wood when it dries. I resorted to soaking in thinned lacquer in order to turn the dried roots. Wonderful color and figure but tear out is terrible. Polyurethane will yellow the wood and make it look ugly. I believe that lacquer is the best finish for the wood. You may as well soak the wood in lacquer because the wood will drink it about as fast as you can spray it on. DAMHIKT
John K, I have a number of pieces that are dry. Mostly in 2" thick blanks for bowls. Light pink heart wood that will darken with lacquer a lacquer finish with white to light yellow sap wood. Sanding it is worse than sanding pine. If you still want some droop me an email. The shipping will not be very much.
I have been selling it to people who collect wood because it isn't normally available. I have pictures somewhere but I don't have time to look for them right now.
When you turn it fresh and wet you are going to get a shower like you have never recieved before from the lathe. Rough turn it thick because tear out is so bad that you will need to remove a lot of wood to get the dried surface smooth. Because it is so water ladden it will crack severly on the end grain. Seal the ends ASAP and leave it in log form as long as possible with the bark on it to help delay the checking. Good luck.
Dave Smith
Purveyor of weird wood in Longview, WA.
Re: I cut one down about 10 years ago.
Rick in Colgate, Wi
>The sections I have had already been cut into firewood lengths, but nearly 30" in diameter. I do expect to take a shower when turning it!
Being somewhat of a rare wood, I do want to utilize what I have.
Have you tried the DNA soak on this type of wood?
Do you have any suitable for spindle turning, 1"-2" or so square, about a foot or so along the grain?
JKJ in East TN
I wasn't using DNA then.
>Thinking about it I guess it was about 5 years ago when I cut it down. I had just gotten my lathe when I thought I would practice with the wood. I didn't do much wet turning with it. I had some real wood like apple and holly that was easier to turn and finish. I don't know for sure but the DNA might help preventing cracks. Please let me know what the outcome is if you use DNA.
Good luck.
Dave Smith
I am pretty sure I was Dave Smith when I got up this morning.
I'll check and let you know.
Re: I wasn't using DNA then.
Charlie Anderson in Southern Maryland
>The dawn redwood I got from you in June didn't need alcohol. It was quite dry. As you said, it's like balsa.
