show me your tear down spray booths
Sascha
>i am in desperate need for ideas for a little spray booth setup. i am very space limited IN the shop, but i can spray outside and build a little booth utside that would stay in place. but i also wouldn't mind ideas for a little tear down booth IN my shop.
i know large pieces of furniture need to be sprayed outside, but my turning i wouldn't mind finding a place in my garage. i want a fan in it and rig it up as good as i can. it doesn't have to be perfect, just good enough to produce a nice finish on my turnings.
pics from you guys would be appreciated, just want to know how you all do it.
thanx guys
sascha
Re: show me your tear down spray booths
>Sascha I have what I'll call an open air booth. I place a fan at my back and the work on a lazy suzan stool. I put this in my doorway so the fan blows the spray out the door. Some days there is a natural breeze that runs from the garage door out the back door. On those days I don't use the fan. This doesn't work as well on really rainy days. I guess the humidity is too high.
Les Robison
>When I had my furniture shop I used two types of tear down booths. The lagre one was made for 3 sheets of 1" foam board used for insulation in houses. I bought it at Home Depot. I cut a hole in the back piece and built a frame to hold a furnace filter on each side of the hole. In the back I placed a box fan (cheapo) in an orientation to suck the air outward. The three pieces were held together using velcro tape to keep them upright. I had a lazy susan table that I placed the work on to spay. I used that booth for 4 years and gave it to another furniture maker who is still using it.
For small work and touchup, I built a similar knock down out of a single sheet of the 1" foam. I again used a smaller furnace filter to catch most of the over spary. This one I set on a table in front of a window in the shop. Take the screen off the window and leave it open for the overspary to escape. You could also mount a small fan to work just like the large one used in the large booth. Hope this helps. Total cost of the setup of both was under a hundred dollars.
Les
