*OT* Cut & Paste again
W.C. Turner
>I should have included this in my other post. Don't you cut & paste things into the Address block in the browser?
Could sombody give me an example or two of something that you would need to cut & paste, & where you would cut & paste it to?
Thankx,
W.C.
Re: *OT* Cut & Paste again
Re: Here's an example.
Al Crandall--NE of Indy--
I dragged the mouse to highlight the above text in your message. Then I used control c to copy the above text from your message, and when I opened this response, I used control v to paste it into this message so that I was sure I didn't induce a typo into it. Lots of times I like to save some portion of a message by putting it into a word document, so I use copy/paste which saves a bunch of typing.
Re: *OT* Cut & Paste again *LINK*
Jorge Castaneda
>WC,
Yes, you can copy an address and paste it in the address window of the browswer, I did highlight and copied the address of your original post and pasted it here. Click on it and will take you there.
WC 's original post
CUT&paste, COPY&paste, drag&drop
A small technical distinction: CUT&PASTE means to REMOVE text (or other object) from one location, then place it at another location. This is often done in word processing applications to reorganize things. Much of what people do is actually COPY&PASTE to copy things to another location. This is done to duplicate text within an application, copy URLs and photos, save interesting messages, ect.
Note that CUT removes but does not erase the text - it just saves it internally in the computer's Clipboard where it can be pasted in the same or another application. On a Windows OS, CTRL-X cuts, CTRL-C copies. (don't know about Mac OS)
An example of true CUT&PASTE would be to move a sentence or word in the message window while composing a message here on Woodcentral:
- position the cursor at one end of the desired text
- hold down the mouse button and drag to highlight the text
- on a PC press Ctrl-X to cut (remove the text and save on clipboard).
- move the cursor to another location and click once to reposition the cursor
- press Ctrl-V to paste the text into that new location.
If you use Ctrl-C (copy) instead of Ctrl-X in this case, you will make a copy of the text rather than move it.
Note there is a quicker way to MOVE a block of highlighted text within and between most browsers and word processors, DRAG&DROP:
- place the mouse pointer anywhere on the highlighted text
- hold down the left mouse button and drag the cursor to a new position
- release the mouse button
You can even drag&drop BETWEEN many applications. For example, if I have Woodcentral open on one monitor and MS Word open on another, I can drag a highlighted block of text from Word and drag&drop it in a Woodcentral to MOVE, or hold down the Control key and drag&drop to COPY.
BTW, another practical application of COPY&PASTE on Woodcentral (and other forums) is to make a backup copy while composing a long and winded message. In my work as 3D graphics tech support, I might work for an hour composing a detailed support message. In rare cases, a glitch can cause a carefully composed message to disappear during posting on any forum. To prevent losing everything and having to start over, I always make a quick copy of long messages before Previewing or Posting:
- press Ctrl-A to highlight the entire message being composed
- press Ctrl-C to copy the entire message to the Clipboard
- open Notepad and press Ctrl-V to paste the entire message
If a disaster happens (and it has), I just start over with the reply and copy the text back to the message board composition window.
JKJ in East TN
Thanks....
W.C. Turner
>for all your responses!! Much appreciated!
Thanks,
W.C.
