Triple Feedback Request
Randy in Langley
>I've been reading the archives with enthusiasm to understand how I can improve on my photo shooting skills. I was recently given a "Photo-Stage" set-up that was used in a crime lab to take photos of evidence and I wanted to convert it in to something usable for my turnings.
I'd like some feedback on my photos and some advice as to how I can make them better. I'd also appreciate some feedback on the pieces in the photos.
The first piece is a hollow form turned from Silver Maple and Purpleheart, it is 9" tall and about 5" in diameter.
The second (posted separately)is a natural edge bowl turned from a chunk of Black Cottonwood that was going to be firewood. It has a little bit of figure in it but certainly nothing to brag about.
Any and all feedback is apprecaited
Re: Triple Feedback Request
Re: Triple Feedback Request Second Photo
Randy in Langley
>Black Cottonwood natural edge bowl. 10" diameter x 4" high.
All feedback appreciated.
Looking Good!
Jorge Castaneda
>Randy,
you are doing good both on the turning and photography.
Keep it up,
Jorge
>Like the natural edge bowl. Like the hollow form also. Focus is a little bit out on the hollow form and much better for the bowl.
Re: Both are Very Nice!
Dick Parr
JamieDonaldson
>The photo set-up looks very good-I would be interested in seeing configuration and light sources. The vessel photo is from a slightly high angle, and needs a little more light in front- you may have placed the vessel too far to the front for the fixed light source.
Randy in Langley
>Here is the Photo Booth Setup. All 4 lamps are fully adjustible, height/angle/swing. All lamps are 250 W Photoflood lights with a temperature of 3200*k. The screens are two layers of Velum on each screen (I found one layer to be too translucient).
Advice & Feedback encouraged.
JamieDonaldson
>Shucks!!?? I thought you had some whiz-bang, big bucks, undercover agent set-up to share, and this is the regular Rube Goldberg set-up we're all tinkerin' with!!! I recommend up-dating your lights to Q/H worklight fixtures- the bulbs you have only last an average of 3 hrs. and change color noticeably during use. Move the box sides and lights forward if possible- that space is just about too small for those turnings.
Randy in Langley
>Jamie,
The setup that I acquired was for "overhead" images and was somewhat dated for "film". That set-up didn't use filters around the objects like the "box" set-up. I've been reading posts here to try to better my images and decided to use the "Boxed Screen" setup that everyone is using. Sorry for disappointing you. ;) I did however use Drafting velum instead of linen sheets since I have a ton of it. Any idea which is better to use?
I'll try Q/H lights on my next turning compared to these lights and post the results. I'll also open up the box a bit, I think that will help with my "hot spots". This box is 24" x 24" x 24", my lathe capacity is 12", how big should I go with the photo booth?
Thank you for the feedback.
