*OT* computer question?
W.C. Turner
>Hi all,
I've been meaning to ask this for a long time, & it slipped my mind.
How does one do the "Cut & Paste" feature on the computer?
Thanks in advance!
W.C.
W.C. Turner
>Hi all,
Thanks in advance!
W.C.
Re: *OT* computer question?
Jorge Castaneda
>WC
To cut highlight what you want and pres Ctrl and c at the same time, to paste Ctrl ans v does it.
Hope this helps
Jorge
Carole in VA
>Or highlight, right-click and select copy. Put your cusror where you want to paste, right-click and hit paste. Always more than one way to do something in Windows. There are several other methods.
Keith Newton
>If you want to highlight more than is showing on the screen, you can click either end of what you are wanting to copy and either drag your cursor down or up until you get to the edge of the screen and it should automatically scroll up or down. If it does not, you can depress the up or down arrow keys while holding down.
One more tip. If you want to copy all of something, just click on it then press control +A, and it will copy everything inside of the highlighted area.
Ken Grunke from SW WI
>"Cut" is a bit different from "Copy"--it means to delete from it's current location while copying to the clipboard at the same time. So it can only be done on editable text. The Cut keyboard shortcut is Ctrl X.
W.C. Turner
>Thanks all for the help!
W.C.
