We value your privacy.
>What do you guys use? My forstner bits are not long enough and I don't have any long drill bits of a large enough diameter. I noticed in another thread where John Lucas mentioned drilling with turning tools but did not mention what tool and how. I have never tried that and don't have a clue how to do it. When I have drilled the depth hole for a HF I have only used a fairly small diameter twist bit.
You don't mention how deep you're looking to drill but there are a lot of long drill bits available.
I don't know how John Lucas hollows with a tool, I use a 3/8" bowl or spindle gouge, start the hole with the flute facing me, turn the tool so the flute is up, keep pushing in, if necessary turn so flute is facing right and bring handle down. You know, I thought this would be easy to describe, guess you have to try it to see what I mean. I move the tool so it drills rather than hollows, when you get the tool in the right position, you'll know it because it will just "drill" in.
>Carol My weed pots must be different than yours. I just take it to the drill press and drill about 1/4" hole 3" deep or so and stick a weed or single flower in.
I do use a turning tool to drill holes for hollowing but I use my bowl gouge. I turn it so the flute is to the left, about 9 oclock or a little toward 10 depending on which bowl gouge and how I've ground it. I just push it in a little and pull it out and do it again.
What I was talking about in the other thread was boring a hole which is different than drilling. The simplest way to describe boring a hole is if you had a cutter that stuck out to the left and only cut on that side. It has a shoulder behind it that is the size hole you need. This keeps it straight. You would need a hole already drilled for this tool to start. What the boring tool does is it cuts on the left side like hollowing. You feed it in and it cuts and doesn't follow the grain. You can also do the same thing with a captured bar system. Mount a couple of pins or a guide of some sort so the bar is aligned with the turning. Then just feed it in. This is the same way a boring bit works in a milling machine.
There are some good articles on boring holes if you do a search under drilling holes for musical flutes. It's been a while since I looked for this info so I don't remember exactlly where.
>I do similar to Ruth. 3/8 spindle straight in flute up. Carefully turn flute left,handle a little right and slowly pull out.One you get used to this you can also cut going in with flute to the side.
Extenders are readily available for Forstner/drill bits that will extend the reach from about 3" to 6". Craft Supplies sells a 6" extender for $11.99 that holds 3/8" diameter shank bits. Woodcraft also sells one, but I don't recall the length or shank size it will accept (I think it might be metric size to fit the Bormax forstner bits). I have one that a local machine shop made for me in trade for a bowl I turned. Be sure to check the shank sizes for any bits that you might want to use with an extender.
>You can buy auger bits that are good for drilling hollowforms, vases, and weedpots. The lathe must go very slow. They are single flute with a screw point to automatically feed the bit in. They are usually available in about a 7" length. You can also get very long ones called ships augers. I use a 1 1/2" diameter x 17" long ships auger to drill my large hollowforms. You have to let the screw control the feed rate. Because they are single flute, they do a good job of ejecting the waste wood.
There is nothing worse than getting a forstner bit stuck deep and not being able to get it out. That's why I don't use bit extenders anymore.
>I have some bits mounted in wooden handles but I've also used them held with vise grips. I drill with the work mounted in the chuck turning at low speed and feed the bit in by hand. I've also drilled by plunging a spindle gouge into the end but it scares me more than the drill bit.
>Carole, I hold drill bits in a pair of pliers (vice-grips) also and 500 is an ok speed. Again, once you try it and see how easy and safe it is, you'll be surprised. Only thing is I make a nice dimple for the bit to sit in instead of trying to keep it centered on a flat piece of wood (ain't gonna happen!). Be sure you're holding the bit level so it goes in straight. If it's not level........well, the wood will let you know! : )
>I use both. The 3/8" extender is used for the Forstner bits, and the 1/2" extender is used for the Silver and Demming drills. Both extend the useful depth about 4" if I recall.
>The thing to remember about extenders is that they are necessarily fatter than the drill shank - around 5/8-3/4", then the grub screws stick out just a little more. So putting a 1/2" bit into one gets you nowhere. They also hold much better on hex-shank drill bits.
>Carole, You can do the drilling with any scaper of the size you need. Just be sure it is sharp and stick it in the middle and push. It should go right in and make a nice straight hole. I use my drop-nosed scraper for small holes and go bigger if needed. Phil
>Another option you might consider-I got some machine drill bits with a #2 Morse taper shank that fit right into the tailstock spindle. Found them in a used tool shop and eBay fairly cheap. I can drill up to 6" deep at 3/4 " or 1" diameter for the glass inserts for live flowers. I also mounted a 3/8" Jacobs type drill chuck on a turned wood handle for hand drilling with smaller bits. Both work well, but so does drilling with a spindle gouge. Different stroke for different folks!
