Powermatic 3520A Tailstock Question
Clem Wixted
>While trying to mount my live center in the tailstock today, I couldn't get it in seat. So I cranked the handle and nothing happened. Still couldn't get the it to seat. Long story short, the shaft was spinning in the tailstock. There was a short pin in the recess in the tailstock. I found a hole for the pin and rotated the shaft so the pin would seat in the grooved slot on the shaft. I rotated the shaft with the slot to the bottom and was able to insert the pin so the shaft wouldn't spin when I cranked the handle.
Now the question.
How hard should I drive the pin to stay in the hole?
The pin doesn't appear to be tapered. There is a hole in the top of the tailstock that appears to be over the pin. I guess that could be used to drive the pin out if it were ever necessary but I haven't cleaned out the hole to check that.
Thanks for your help,
Clem
Re: Powermatic 3520A Tailstock Question
>Clem The pin is tapered. Try to find the narrow end and put it in. Then tap it with a hammer. I didn't hit mine very hard, just a firm gentle tap. It hasn't come out since. They must not put these in very firmly because my best friend has his drop out also. Neither of us have had any problems after reinstalling them.
I would suggest if you own a 3520 that you check this pin, which is on the underside of the quill inside the tailstock cavity. Just tapp it with a hammer and you shouldn't have any problems.
Clem Wixted
>Thanks, John.
I guess I'm not the only one to have this happen. My lathe has just been sitting there and maybe the heating and cooling this summer helped the pin move around.
Clem
