REAL MILK PAINT
Vacuum chuck neoprene
Sean Troy
>I think I need to replace my neoprene on my vacuum drum. It is leaving a black ring around the inside of the bowls. What do you all use for the vacuum drum seal? Where do you get what you use? Thanks, Sean
Re: Vacuum chuck neoprene
Stuart Johnson
>I use Foamies from Wal-Mart. The stuff is 2mm thick, peel and stick sheets. You can find it in the craft section.
Re: Vacuum chuck neoprene *LINK*
Bob Elliott
>I use this along with a light coating of spray contact cement. David Lancaster demonstrated a similar product @ the AAW Symposium in Kansas.
U-Haul Store cushion foam
Dawn Adams
>How do you take the neoprene off? I would like to change to something that is not BLACK as well. I am always afraid it will mark my bowls.
vicmarc.fan
>I use artificial shamos from almost auto supply store. It comes folded up and the creases don't seem to hurt the seal. One piece makes several seals.
Ron
Bart Rhoads
>I also use the Foamies from Walmart. They are white so they wont leave a black ring. I have been using them for about 2 yrs, with no problem, on a regular basis.
Sean Troy
>Thanks all for the help. I just happened to be going to wal-mart so I picked up some white Foamies. I think they'll work just fine and at .49 each. Sean
