Speaking of toolrest height...
Russ Fairfield
>They don't get any higher than this, in more ways than one...
I have saved this one for these discussions on the height of the tool rest. The tool is most likely a ring-tool because that was in common use for bowl turning at the time of this photo.
Re: Speaking of toolrest height...
Paul in Phoenix
>Talk about in-your-face turning...one small slip and yer missin' some teeth.
>Great photo Russ. I would guess ring tool or hook tool. Bet he doesn't have back problems.
Ron In Drums PA
>Neat!
It looks like he's coring bowl blanks
makes perfect since the way he is turing.
John Cotten
>He is a production turner, completely different from most of the bowls we turn now. He is using a turning hook, and the bowl blank is mounted high so he can clearly see the cut he is making and not have to bend over to try and see the work. With the tool rested on the shoulder, it would be comfortable to use and he is walking into the cut instead of using his arms only.
Looking at the way the leather strap is wound around the work piece (notice one end is going up into the air and the other is going down under the lathe), I am guessing this is a spring pole lathe and so it is a respricating lathe, not an engine lathe that only turns in one direction. Not much change of the blank having enough speed to do more than fall off onto the floor if it did come loose.
Paul Londo
>I make carrying yokes and I always figured I could turn a yoke on a lathe. I finally did it last month and it sure is great to see some documentation of someone else who has done it.
Wes Jones
>What I first thought was the toolrest is too far from the workpiece. Is it possible that the lathe is turning in the opposite direction from what we are used to? Note what appears to be a hook holding down the shaft of the tool adjacent to the fingers of the turner's left hand. If so, the "toolrest" is just a convenient support for the toolhandle.
Or, I could be all wet. Flame away!
Wes Jones
