low handle turning
low handle turning
low handle turning
tdaniel
>here is a picture of low handle position turning. With the tool used as shown there is virtually no chance of a catch because the tool will back out of a cut that it cannot handle. Raising the handle will cause the tool to be forced to cut through whatever grain comes to it. Note the cut is made on "the equator" so the toolrest must be much lower.
Re: low handle turning
tdaniel
>try again
another view
tdaniel
Glenn Hodges
>Thanks for giving us the low down, Terry.
>That's how you do such good work! You have your supervisor watching and approving your work.
Re: another view
Mac
>I've always known that you were short,but when did the double chin kick in?
It's an Irish thing.....
tdaniel
>you wouldn't understand :)
apprentice
tdaniel
>Yeah, I still miss the little guy. I still have his little sanding mitt but I can't get his replacement to use it. Buddy liked working in the shop. A 10 hour day was fine with him. Every shop needs a shop dog....(or cat, yuck).
Keith Tompkins
Re: another view
Keith Tompkins
>Terry, the other advantage of turning on the "equator" is that you do not have to change the tool handle height, and roll the tool at the same time to keep the bevel rubbing and the tool cutting. That makes it easier to make a clean consistant profile. I use my bowl gouge just as you show, I also use a push cut with the handle not as steep, but the principle is the same.
Re: another view
woodspinner/ Bill Hale
>TD
Where do you get the long shaft tool ?
Bill in Dolores Colorado
long handled gouge
tdaniel
>I use the Sorby Texas handled gouges which I purchase at Highland Hardware and I also have had some extra long aluminum handles made which I use with the double ended One-way gouges. To cut with the side you need a deep fluted gouge with a smooth "U" shape. Perhaps someone else can jump in here but I do not think the "V" fluted gouges would work well at this angle?
