THE WOODRAT IS BACK!
tool rest height
tool rest height
tool rest height
>Keith You know I love you man so this is just for fun. For those who haven't followed the tool rest height debate keith challenged us to show that we can turn with the tool rest too high or too low.
This is with the tool rest about 3/8" above the top of the spindle and about 3/8" below the spindle. I always suggest using your body to control the cut. In this photo I was using my head, literally.
Re: tool rest height
>This is my normal turning height. Notice that I like the tool handle on my hip. On the right are the coves turned from each height. Turning with the tool rest too low was difficult to control because I could only use my hands. When I used my head to control the cut on the tool rest high I got a very nice cut.
vertical tool rest
>Here is an example of turning with the tool rest vertical instead of horizontal. It actually worked better than I had though. I had a lot of control although it's difficult to see the cutter.
>Here is the way I turn beads on the face of my mirrors. The tool rest is about 3/4" or more above center. This allows me to roll the tool very similar to the way you would when you turn a bead on a spindle. If I keep the tool rest at the center I have to use the tool completely different cutting from the left and right.
Keith Tompkins
Keith Tompkins
>John, I love you too, man! I think it's good to see how others are turning, to study their technique. Sometimes you may get a good idea from a small part of a technique, even though you disagree with the rest. I gotta' try that below center technique!
>Keith The best one I've seen was Graham Priddle from New Zealand turning with his gouge upside down and the below the tool rest. He was joking about our lathes turning the wrong way on this side of the world.
Brad Vietje
Brad Vietje
>I turn small details on ornament finials with the rest quite a ways "too low", keeping the tip of the tool up, the handle way down towards the floor, and shear cutting along the wings of the spindle- or detail gouge -- works very well. If the pic appears, that's about 3/4" to 1" below center.
Safe Spinning,
Brad Vietje
Thetford, VT
