McNaughton bowl saver instructions
Chipster
>I just received my McNaughton bowl saver yesterday. I went for the gusto and ordered the large, combination kit. Okay, enough for the gloat. Now to the reason for my posting.
I have never seen a product with a more challenging instruction set. I've bought things with poor instructions before, but this wins the prize. My pre-purchase research told me that it was bad, but wow!!
As a result, I've ordered Mike Mahoney's video.
Does anyone have any other suggestions for getting the most out of this product?
Re: McNaughton bowl saver instructions
Re: McNaughton bowl saver instructions *LINK*
Bill Grumbine (Kutztown PA)
>Hi Chipster
You can check an article I have on my website at the link below. I show people how to use this tool all the time, and little old ladies can use it with ease once they see how it is done.
Bill
Coring Article
Carole in VA
>We can??? Oh, goodie! :)
Joe Staller
>I also purchased the Mahoney video, but still struggled mightily, primarily at the start of the cut. I finally figured out that I had to ignore Mike's advice to move the tool rest as close as possible to the blank. At least on my tool, the first inch of the knife does not have parallel sides and would twist in the tool gate. I've learned to start with the tool rest back an inch or two, and only move it closer to the blank after I have the cut established. Once I figured that out, I no longer fear my coring tool.
Dawn Adams
>If you live close to Bill, go spend some time with him. It only took him about 5 minutes to show me how to use this tool. Now this little 'old?' lady can use the tool with no problem.
Chipster
>I wished I lived close to Bill. For now, I have to resort to buying is bowl-making video and picking his (and everyone else's) brain electronically.
woodspinner/ Bill Hale
>If you try to do it yourself this is a very high learning tool.
Get some help watching someone use it and you will save a lot of frustration.
A couple of notes, use it at about 700 rpm, gentle cuts and learn on green wood.
Good turning and be safe
Bill in Dolores Colorado
McNaughton bowl saver - sharpening?
Devon Palmer
>Hey, how often does everyone sharp their blades? (I know.... when they're Dull LOL), but, realistically, can you do a coupla 15 inch cores between sharpenings?
- Devo
Re: McNaughton bowl saver - sharpening?
ob obrien In Pensacola
>You don't sharpen them like a gouge. You hone them with a diamond file. This is because the tip that needs sharpening is a special area on the tip and you dont want to grind it off. It has a convex curve and after repeated use and honeing, when the convex shape has been honed off, then you take it to the grinder. Just take a second or two after each coring. Maybe more if your coring hard or dry wood. Hope this answers your question.
>Special note for anyone with an "older" set that uses the single-pitched skew grind. In speaking with Mahoney at KC, he told me that I should re-grind my knives to the mid-point configuration now used because it gives better control and prevents the kerf tenon from fracturing into either the core or the remaining rough bowl (or both). Also mentioned, the top surface of the knife should NEVER be ground because that consists of a thin layer of HSS that is bonded to the mild steel of the knife body to do the real cutting; most that should be done there is a very light lapping stroke with a hone to take off the wire edged burr.
M
adrien
>Mark, I don't speak so well the English, having been in this country only a short distance, so would you kindly elaborate on regrinding the knives "to the mid-point configuration" as against a "single-pitched screw grind"?
Re: McNaughton bowl saver grind
>I'll try with a little typo-grafics
My set, bought 2 years ago had knives ground like a skew like
this /
The new sets are ground to a midpoint like
this ^
To regrind the knife, you set up with the knife held to the right and a slight up angle so that the grind wheel removes the old point and establishes a new point in the center of the knife's cutting edge.
I'll try to take a photo and post it tomorrow.
ps Adrien
>Since I'm only about 30 minutes from you, you're welcom to stop by and see the grind in person.
M
[for e-mail drop the "2"]
