Batteries for Airmaster helmet
Larry Skendzel
>Replacement batteries for the Airmaster helmet are very expensive. Fog Tanner had a message about making replacement batteries but I did not follow the procedure. Has anyone found a source to replace the batteries or information on how to make your own batteries.
Larry Skendzel
Re: Batteries for Airmaster helmet
George Balock
George Balock
>Larry,
Bill Grumbine said something about this when he demonstrated at our club meeting. Send him a mail.
George
Very Simple...
Peter Teubel
>If the battery pack is dead, take it apart. don't worry about ruining it...its dead anyway, so who cares? Inside, you'll probably find 3 D cells (I'm going by my AirMate 3, yours might be different). Look how they are wired, do the same with replacement Lithium Ion or Nickel Metal Hydride D cells from RadioShack (no sense is using the same old NiCad style batteries when you can upgrade the performance), glue/screw/tape the pack together and party on. Is really quiet simple.
My buddy did the same with his 3M PowerVisor. The new fully charged Lithium Ion battery back ran the visor for 13 HOURS (constantly ON). 3 times longer than the stock battery pack.
Re: Very Simple...
>>Look how they are wired, do the same with replacement...
One caution. Batteries in packs are normally wired together by spot welding a tab on each end. The battery stores have the equipment for this. With a good flux it is possible to solder directly to the ends of many batteries but you run the risk of damage from the heat.
You can purchase batteries that have spot-welded tabs for soldering, for example: http://www.primecell.com/pcother.htm
JKJ in East TN
Re: Very Simple...
woodspinner/ Bill Hale
>Thanks John that is a good site.
If you put the address on a seperate line in the text it becomes clickable and we don't have to cut and paste.
Thanks again Bill in Dolores Colorado
Re: Very Simple...
I've used the Optional Link but have not heard about the separate line. I'll try that:
JKJ in East TN
