Here's a poser. Thoughts?________
Rod Peterson -- Ormond Beach
>I just disassembled my old Sears round tube lathe in preparation for sale and installation of my Delta 46-700. I'll be kind of sad to see the Sears go, because I've been enjoying saying I have three lathes (Jet Mini). Anyway, I decided early on that the flimsy steel stand that came with the Delta wasn't going to be used, so I'm working on Plan A (since what some might have called Plan A wasn't ever a consideration).
The stand I built for the Craftsman is fairly substantial…for a wood only product (no snickering, you guys with really heavy iron), and I thought I might put it to use. Acutally, I am going to put it to use. I only have to cut down the rear brace to accommodate the shorter span of mounting holes between the Craftsman and the Delta. I may beef up the bracing a bit—after all, the Delta is a more substantial and more powerful lathe than the Sears…I figure I can hang sand bags on it eventually or even build some sand bins. But that's for later…Here's a pic:
Shop built lathe stand
What the poser part is, I had a brainstorm. How about if I build a little platform for the Jet that will sit on the ways of the Delta, that I can either clamp or bolt in place for when I want to use the Jet for a project?
The actual height of the centers won't be that much different (is that an issue even if they were quite a bit different?), and so far, I'm the only one turning, so there won't be that much call for two lathes running, and in any event, even if there were, I can still set the Jet up on the WorkMutt or the chop saw stand.
Anyone think I'm crazy? Wait, let me rephrase that—anyone think this is an unworkable idea?
I use the same tools, the same drive spurs, the same face plates, the same tail centers, the same chuck (both lathes have #2 MT and 1"-8 spindle). Everything would be really convenient, and I get to save some floor space, especially if I build a mobile base for it.
I appreciate your thoughts.
Rod
Re: Here's a poser. Thoughts?________
Lan Brady
>Rod,
Your Wood stand is beefier than the stock Delta stand with the exception of of the foot print. Your wood frame is a bit narrow and short for balancing an out of round piece. With the delta min. speed of 500 rpms. You may notice the narrow stance.
Lan
albertabob
>"Anyway, I decided early on that the flimsy steel stand that came with the Delta wasn't going to be used, so I'm working on Plan A (since what some might have called Plan A wasn't ever a consideration). "
Rod the stand in the pic seems to be about 36" tall. I would cut 2 cross ties fom 4x4 to fit under the stand to bring it up another 4" and to widen the stance of the base.
Delta really goofed with the shaping of the ways and did not allow you a lot of choices for mounting the lathe.
I would also consider building on a "Vee" tray under the ways to catch the debris.
You have the room and it makes clean up much faster.
Don't forget the lathes spew debris at the operator not the wall.
The stand I built for the Craftsman is fairly substantial…for a wood stand"
There is nothing wrong with it,-just mortise in an extra pair of braces at mid level and she will be rock solid.\
enjoy
AlbertaBob
Ron in Drums PA
>The only thing I would add is a sand box between the legs for some ballast and you are ready to go.
Okay, how about this?________
>Comments are to each of youse guys—just here for convenience.
Okay, here's some info:
The height of my original stand is 32", putting the top of the lathe bed as shown in the first picture at 36"…that's nearly elbow height for me. The width of my stand is ≈ 29" on center to accommodate the mounting holes of the Delta. You can see from the first picture that the original width was probably 2' or more wider. I can stil do that, as I haven't cut the back brace which was the only dimensioning member for that aspect. The depth is ≈ 20".
I temporarily set 2x4s on edge on top of the stand to simulate partially letting in a couple of 2x6s to A) provide extra height (not sure I need it, although that would vary depending on implementation), and 2) provide greater stance to the stand. See below:
Lathe stand, part deux
The Delta stand spans 43" side to side at the feet—quite a bit more than my stand, however my stand has much more than the 17" front to back at the feet of the Delta. In my opinion, that buys me more stability for out-of-round stock than the left-to-right span.
Nevertheless, there are all sorts of other things I can do. In addition to extending the length of the stand by the use of mounting rails (above) I could let in a stretcher between the cross members at the bottom of each of the end panels. That would also be a good foot rest for those times when I feel the urge (to rest my foot). Keep in mind those semicircular arches of plywood under the stretcher are gussets which stiffen the assembly considerably.
My goal was and still is to have the stand as open as possible. I've already learned to hate clearing off a flat surface under a lathe. I don't want any more obstructions under there than I have to.
As I said in my first post, there's space and all kinds of ideas for adding weight.
Anyway, no one has yet addressed my question of running my Jet on top of the Delta. That was really what I was asking about, but I appreciate the thoughts on the stand so far.
Rod
Re: I'm a big fan of combining "feetprints".
Al Crandall--NE of Indy--
>Hi Rod. Don't get your hopes up, there will be no referrences to heat in this post. To me the obvious solution is to install an axle below and slightly behind the Delta and mount the Jet on a torsion box which hangs from and pivots on the axle. When its Delta time, the Jet is below, behind, and out of the way of the lathe in use. It can be covered with a tarp or something so the chips can be shaken off it at clean up time. When its Jet time, the little monster is pivoted up into place level with and in front of the Delta and the appropriate bracing is installed to support it. When its time to take the Jet on vacation, its torsion box can be unhooked from the Delta and away you go.
I'll send you dimensioned plans for $500, old buddy.
Paul in Phoenix
>Rod, I would inclose the entire stand and fill it with as much dry sand as possible. I think you would see a huge difference in how the lathe behaves.
>Would your Jet fit between the verticals of your stand? How about storing it under the Delta? When not in use, it could serve as part of the ballast. As far as mounting it on the ways of the Delta, Why not? You can make a base for it with a couple of plates that will engage the ways of the Delta. Two sturdy steel buttons that will drop between and then rotate into the ways and tighten them with a wrench. I assume you will not be turning huge out of balance things on the mini so it should work even if the mounting is not super solid.
You do need a sand box and some left to right bracing. I have the same lathe and it is on that flimsy stand. Don't use it anymore, but when we did we used to just follow it around the shop while truing the blanks.
You might be able to pivot the mine as others have suggested or just put it on a shelf. Cover it to keep the chips off.
My only concern would be that I would want to switch lathes too frequently or use both at the same time for different steps in a process. I don't like multipurpose tools for that reason. AS an example, I have a router table in the wing of my TS and they share the fence. Sounds great, except that fairly often I want to cut a strip molding on the edge of a board, rip it off and mold another. I end up clamping a fancy stick onto the table for the router and using the fence for the TS.
JamieDonaldson
>You would really benefit from more diagonal bracing, like 1/2" plywood screwed on front and back to form a box, then clant the top toward the back slightly so that shavings slide off. Fill the box with river gravel, never sand- it escapes and ruins things like switches, bearings,etc. Gravel is much easier to control, and does the same job, only better!
Bart Leetch
>I tried the Jet on the Delta ways trick its to high I ended up with it on my Workmate.
Bart Leetch
>As you can see the Jet mini was to high on top of the Delta.
This was a test & I'm sure the cans of Kilz primer would have been the death of me.
Bart Leetch
>My lathe stand & Delta lathe weighs in at about 420 lbs. I move it with a big floor jack.
JamieDonaldson
>Rod- here's an idea for your Delta 700. Years ago I needed a portable demo lathe for bowls, and built 2"+ riser blocks for head and tailstock to increase swing capacity. Also cut off both ends of bed as well as a few other mods, but it works like a champ- well, like a Delta!
River gravel...
Paul in Phoenix, AZ
>...never thought of that.
Re: River gravel...
JamieDonaldson
>I also have my old General 160V stacked full of bricks and enclosed.
