Re: Which HVLP system you guys use *LINK*
>Sascha,
If you're looking to use solvent lacquer in a gun system (as opposed to spray cans), you do NOT want a turbine system like the Fuji, Apollo, Wagner, etc. because all of those units warm up the air as it passes through the turbine unit, and the hot air will gel or dry your lacquer before it gets from the gun's tip to the wood surface. The self-contained turbine systems are designed for waterborne finishes were the warming of the finish in the gun helps with the finish drying on the surface.
If you have a compressor, a pressure gun may be your better bet, especially for solvent finishes like NC lacquer and shellac, although for small items like turnings I think you'll find that a spray can that saves you all that setup time and cleaning, etc. will be your best option for lacquer finishes, although a small compressor and either a touch-up gun or one of the little Critter sprayers will do well without much expense. Of course, if you're into spending the bucks, look into the Asturo and Walcom gun sets with pressure feeds etc. I have an Asturo with a 2-quart pressure pot for flatwork finishing that will lay down waterborne or solvent finishes almost glass smooth off-the-gun.
Please remember that you should not be spraying finish in an enclosed space. Your "booth" needs to be exhausted outside, and you will need a real, properly "organic vapor" rated, filter mask. Actually, you should have one of those even if you use a spray can.
You will do well to visit Jeff Jewitt's website at the link. You can ask your questions of Jeff directly and also post them on his finishing forum.
Homestead
