vacum chuck help
vacum chuck help
vacum chuck help
Gil Mitchell
>can a delta 46-700 be fitted with a vacum chuck? I,ve bought the fittings but there are no threads to screw it on to.
Re: vacum chuck help
Something's Not Defined
>Gil,
That lathe has a threaded spindle. Where else did you plan on mounting the chuck?
>Gil Get one of the EZ vacuum adaptors from Packard's. It will go right through the headstock and handwheel. Then you'll need to build or buy a vacuum chuck or two. You can build the EZ vacuum chuck. Send me and e-mail so I can send you the plans.
