First attempt at Photographing my work
Devon Palmer
>All,
Finally got some pictures taken of my stuff. I used to varitone background mentioned in the AAW "American Woodturner" issue from earlier this year. Taken with two halogen desk lamps on either side and Flourescent overhead. Any suggestions on how I can improve the quality? (aka, what is wrong with this picture - don't be kind, I'm a big boy :)) My shop space is super limited, but, building a photobox isn't out of question if it would really help.
Spalted Poplar and Soft maple, Tung Oil per Russ's instructions, and Buffed.
OT, I've been storing my Tung oil in the fridge to extend its shelf life between applications. I usually take it out a coupla hours and let it warm to room temp before applying. Its seems to help, but, is keeping it cool bad?
Devon Palmer, Woodturning newbie, Columbus Ohio...
Re: First attempt at Photographing my work
Gil Mitchell
>I wish I could get a picture to come out that nice. GOOD JOB!!!!
Steven Antonucci
Never been a studio photographer, but...
steve antonucci
>I would offer the following advice- (serious amateur photographer at one time)
1.) two light sources cast two distinct shadows, which is distracting. On source, with a diffuser (white bed sheet) will flatten out the shadows.
2.) Unless the two objects are part of a grouping, shoot them separately.
3.) Bounce your light off of the diffuser to eliminate hotspots.
again, never was one for studio work, but those three things jumped out at me.
Steve
Re: Never been a studio photographer, but...
JamieDonaldson
>Steve made a couple of good suggestions, but a sheet doesn't work for bouncing light -white cardboard or foamcore type panels reflect, and cloth absorbs light. A simple light box large enough to hold a turning and a light source (such as a single Q/H 500w work light) pointed up is easily constructed from PVC. Multiple shadows are distracting, and hard shadows that hide details should be filled with light from the main source bounced off of a white or silver foil board(bounce card) on the side opposite the main light. The ideal is to KISS and create repeatable good image results.
>Jamie You missed the most obvious thing. He has 2 different color light sources. He has flourescent and incandescent. Must be the Mint Julips you retiree's are always sipping. Jamie's right, you shoot through cloth and bounce light off of board. Cloth is a very inefficient reflector. Either system works, shooting through the cloth or bouncing light.
Your exposure is good it's just the multiple shadows and different colors that throw it off. Stick with all incandescent like your quartz lights or all Flourescent but not both. I prefen incandescent lighting because Flourescents come in all colors and your camera usually only has one Flourescent setting. Incandescents also come in different color temperatures but usually they are all orange so it's easy for the camera to get close to the right color and your photo software can correct the rest if needed.
George Van in WI
>Nice bowls Devon. I need to make a booth soon!
Sascha
>i just finished my booth and jamie and john helped me a great deal. i use the main light on the right to bounce off a silvery piece of cardboard that's attached to the wall. shining it directly into the booth was a bit bright for my taste. i also have a gold reflector underneath the silver.
on the left side, i put a white foam core board to reflect the light. i also have another gold one behind the white. the pics look actually cool with the gold but it doesn't work on all pieces. i am still tweaking it, but i have a TV hooked up to it so i don't have to look through the camera to see if it is lighted good.
even though the colors on the TV are not 100%, it's pretty close to the real image.
Sascha
>by the way, i don't use the flash on the camera, it's just attached to it. just thought i mention it so i don't start any confusion
and here another angle
Ben Aragon
>Great job, the bowls look great too.
Ben
JamieDonaldson
>Now for some fine tuning. The bounce board on the L side should be moved forward and angled toward the turning- move it around until the shadows are filled just right- I made a holder out of coat hanger wire to keep it in proper position. Make sure any other light sources are not affecting the area of the light box, and then adjust the TV color controls to match the camera image output- it is very beneficial to color balance all of the elements to get better consistancy of results.
JamieDonaldson
>And what's with the stick poked thru the top center?
Bob R
>I have never seen a photo that was perfect...(a opinion).
The bowls look GRRRREAT.
Bob R
WestMac Turning
JamieDonaldson
>Come on, John- the mixed color balance was not the most obvious problem, and didn't look to bad either!
Devon Palmer
>Fantastic!
Thanks kindly for all the responses....
Jamie, I'm going to plagerize (*gasp*) your photobooth setup. the PVC setup looks awesome. I really like the idea of using a TV for the lighting too. I have a small wireless camera that would be perfect for that. I'll have to invest in some photogrey as well.
- Devo
