200+ woodworking book reviews
hollow form help
hollow form help
hollow form help
gary clarke
>I have my first hollow form on my lathe and I need help in making the top plug and in turning the bottom after the plug is in. The opening for the plug to fit is 1.25 inches and I plan to have the bottom about 2in in diameter. Any help and or reference articles would be appreciated. thanks
Re: hollow form help
Re: hollow form help *LINK*
Ken Grunke from SW WI
>Gary, not sure what you mean by top plug--what kind of hollow form is it? A pic would help.
Maybe I can give some good advice on turning the bottom--there's a lathe fixture called the Kirsten Kone, which holds a hollow vessel for turning the base. Check out the link below, you'll see a pdf file about it.
You can make your own using a 1/2" endmill holder with a morse taper shank to fit your headstock, plus a 1/2" shaft with a padded end, and a wooden cone with a setscrew. It will become clear after you look at the article.
San Diego Woodturners Tips and Techniques
gary clarke
>thank you Ken
Chris Wright
>Hey Gary,
Here is a method that I use to 'jam chuck' hollow forms. There's two photos, so I'll post a follow up to this message. Holding the piece at the shoulder is much more stable than holding it at the opening in my opinion, but to each his own.
Chris Wright
>Second picture with hollow form being held...
>I use Dicky The Stick. Its a stick I made that has a Morse taper that fits into my headstock shaft. The stick is about the size of the hole in the HF and long enough to reach the bottom. There is a small hole int eh end of the stick and I leave a nub in the center of the HF in the bottom. (There is method on my madness, an excuse to leave the accursed numb in the bottom.) I put a scrap of carpet pad in the form and the stick in the head stock and engage the nub through the pad into the end of the stick. Bring up the tail stock and press it home. If the hole in the HF is too large, I wrap tape around the stick to fill the space. Turn on the lathe and shape the bottom. This way nothing touches the outside of the HF and there is no chance of leaving a mark or a ring. No chance of collapsing it. The pressure is directly through the bottom. Also, if you know exactly how Long Dicky the Stick is, you know exactly where the interior bottom is and have little or no chance of cutting through it. I use a square and mark a "plumb" line down to the ways of the lathe and then I can square it back up onto the form.
